bleed cooling system?
Old Dec 31, 2010 | 12:08 AM
drjoe171's Avatar
drjoe171
I just drained water to add antifreeze. It took almost 20 min for the upper hose to get hot but it happened all of a sudden so pretty sure there is a thermostat in there and laser temp gun showed head by thermo housing around 180 or so.
I had the heater temp all the way up and it threw heat normally but it sounds like water is running with air behind the dashboard.
Is there a way to bleed these systems?
Main rad cap fill is full even after the thermostat opened.
92 straight 6,
oh, and whose idea was it to make a virtually clear (very slight yellowish) antifreeze?
Thanks
Old Dec 31, 2010 | 12:33 AM
88n94's Avatar
88n94
It sounds like yours is pretty well bled. Let it run another 20 minutes while watching the temperature guage to make sure the engine doesn't overheat. I can't explain the noise in your second paragraph. My '88 with the straight six doesn't bleed so easily. I have to disconnect one of the heater hoses by the block to let the air out so the block can fill with coolant. I prefer the Texaco green colored anti-freeze, but to each his own.
zjmj17
Dec 10, 2016 05:01 PM
paerhardt
1983 - 2012 Ranger & B-Series
21
Dec 13, 2015 10:55 PM
drjsparker
Jul 10, 2013 10:16 PM
memphis_made
1997 - 2003 F150
Mar 24, 2013 04:16 PM
HangGlider
Jun 7, 2007 07:49 AM
