Rear Heater Core
Old Dec 30, 2010 | 08:26 PM
madsonp's Avatar
madsonp
Rear Heater Core
Does anyone have a good set of instructions for replacing the rear heater core on a 99 expy ? The main thing I need to know is, does the AC system need to be discharged to replace the core ?
Old Dec 30, 2010 | 09:32 PM
cleaningbug94's Avatar
cleaningbug94
REMOVAL & INSTALLATION
1997-99F-250, F-350 and F-Super Duty models
Fig. Fig. 1 Heater core removal-1997-98 F-250, F-350 and F-Super Duty models
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
Disconnect the negative battery cable.
Drain and recycle the engine coolant.
Disconnect the coolant hoses at the heater core tubes.
Remove the glove compartment.
Position the Rear Anti-lock Brake System (RABS) module to the side.
From inside the passenger's compartment, remove the 7 screws that secure the heater core access cover to the plenum chamber.
Disconnect the vacuum source, but leave the vacuum harness connected to the cover and remove the cover.
Remove the heater core.To install:
Installation is the reverse of removal. Replace any damaged sealer.
F-150 and F-250
Fig. Fig. 2 Remove the A/C plenum demister screw and remove the A/C plenum demister adapter
Fig. Fig. 3 Disconnect the vacuum line
Fig. Fig. 4 Remove the heater core bracket
Fig. Fig. 5 Remove the 13 retaining screws and remove the plenum chamber top
Fig. Fig. 6 Remove the heater core
CAUTION
Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
Disconnect the battery.
Remove the instrument panel. Refer to .
Compress the holding tabs and disconnect the heater water hoses at the heater core.
Remove the A/C plenum demister screw and remove the A/C plenum demister adapter.
Disconnect the vacuum line.
Remove the heater core bracket.
Remove the 13 retaining screws and remove the plenum chamber top.
Remove the blend door assembly from the case.
The installation is the reverse of the removal.
Expedition and Navigator
Fig. Fig. 7 Remove the A/C plenum demister screw and remove the A/C plenum demister adapter
Fig. Fig. 8 Disconnect the vacuum line
Fig. Fig. 9 Remove the heater core bracket
Fig. Fig. 10 Remove the 13 retaining screws and remove the plenum chamber top
Fig. Fig. 11 Remove the heater core
Disconnect the battery ground cable.
CAUTION
If equipped with the 5.4L 4V engine, remove the junction block splash shield.
If equipped with the 5.4L 4V engine, remove the bolts and disconnect the cable ends from the starter relay.
If equipped with the 5.4L 4V engine, remove the junction block bracket.
Disconnect the heater core hose couplings.
Remove the retaining screw and remove the A/C plenum demister adapter.
Disconnect the vacuum line from the A/C plenum demister adapter.
Remove the 13 plenum chamber top retaining screws.
Remove the plenum chamber top.
1999-00 F-250SD, F-350 and F-Super Duty Models
Fig. Fig. 12 Remove the electronic blend door actuator and bracket assembly
Fig. Fig. 13 Remove the heater core cover screws and ...
Fig. Fig. 14 ... remove the cover
Fig. Fig. 15 Remove the heater core from the housing
CAUTION
Disconnect the heater water hoses from the heater core.
Disengage the stops and lower the glove compartment door.
Remove the electronic blend door actuator and bracket assembly.
WARNING
The heater core cover must be raised vertically before removal to avoid damage to the heater core housing.
Remove the heater core cover screws and remove the cover.
Remove the heater core from the housing.
To install:
WARNING
Position the temperature blend door manually to properly align the actuator and the door. Do not power the actuator electrically. If it is not engaged with the temperature blend door, damage to the actuator may occur.
Add gasket between housing and cover before installing cover.
Got this from autozone
Old Dec 31, 2010 | 07:06 AM
alwaysfords41's Avatar
alwaysfords41
Those directions are for a front core.
Old Dec 31, 2010 | 04:35 PM
madsonp's Avatar
madsonp
Never mind, figured it out myself. Pulled it all apart, put it all back together, it wasn't that bad to replace. Guess I should of took photos so I could write some instructions up.
Old Nov 17, 2011 | 05:24 AM
cg22's Avatar
cg22
Madsonp,
Did you end up having to open up the AC system in order to replace the rear heater core? Nobody did ever answer your question....
Old Nov 17, 2011 | 08:30 PM
madsonp's Avatar
madsonp
Originally Posted by cg22
Madsonp,
No, you don't have to open the AC system to do it.
tabijan
Jun 23, 2014 06:31 AM
brandon olson
1997 - 2003 F150
13
Dec 30, 2013 08:02 AM
JasonBrod
1997 - 2003 F150
Oct 4, 2012 02:05 PM
case310350
May 8, 2012 11:48 PM
roushboy
1983 - 2012 Ranger & B-Series
May 18, 2011 01:59 PM
