WHITE SMOKE AND LAG
Old Dec 30, 2010 | 07:36 PM
BFOULK's Avatar
BFOULK
WHITE SMOKE AND LAG
2003 F250 6.0 TRUCK HAS TURBO LAG AND SOME TIMES WILL BLOW OUT WHITE SMOKE?
Old Dec 30, 2010 | 09:12 PM
wulfman's Avatar
wulfman
Wellcome to FTE try this down on the 6.0 diesel section that is where the 6.0 experts are, they are very helpfull and friendly.
Old Dec 30, 2010 | 09:56 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.0L Powerstroke Diesel forum.
Old Dec 30, 2010 | 10:19 PM
smokersteve's Avatar
smokersteve
What is your coolant level in the degas bottle?
Is there any coolant that has been pushed out of the cap?
Look at the egr valve and see if it is all wet. It should be dry.
Here is a link to where the egr valve is.
https://www.ford-trucks.com/forums/8...ke-diesel.html
Old Dec 31, 2010 | 05:05 AM
gearloose1's Avatar
gearloose1
Did you warm it up first?
Using cetane boost? antigel?
Old Dec 31, 2010 | 11:15 AM
smokersteve
If it is sometimes it could just be moisture in the exhaust system from outside.
Do you have any codes? You may want to clean the turbo.
Old Dec 31, 2010 | 04:58 PM
Captain1's Avatar
Captain1
Sounds like a head gasket to me!
Old Dec 31, 2010 | 05:19 PM
gearloose1's Avatar
gearloose1
Lets wait until OP comes back with a more concise description.
Mine (nothing wrong) does the same.. smoke and bog.. until it warms properly.
Normal by my book --- what happens where I am is cold enough to trip up the engine.
Old Dec 31, 2010 | 10:43 PM
Unrealo4's Avatar
Unrealo4
I thought blowing white smoke out of the tailpipe. 99% of time is a EGR cooler/Oil Cooler Failure? With bad HG's it just pukes out of the degas bottle cap. Ive not heard of one smokeing white that was caused by HG's.
Old Dec 31, 2010 | 11:53 PM
Captain1's Avatar
Captain1
When a head gasket blows it allows antifreeze in the cylinder causing white smoke.I have had two do it. Depends on which side of the headngasket u blow. Bent 7 rods on a duramax like this. Still ran but white smoke and real lagy. Guess 400 hp nitrous isnt really good for them but there was only one way to find out back then.
Old Jan 1, 2011 | 01:12 AM
Unrealo4's Avatar
Unrealo4
Right but on a 6.0 when the head gaskets go bad the synmtoms are not the same as a duramax.
Workin F350
Jul 9, 2020 08:33 PM
JustinF08
6.4L Power Stroke Diesel
Oct 15, 2014 04:12 AM
Tormz
Dec 14, 2011 07:21 AM
WhiteBeast-05-powers
Jun 21, 2011 12:13 PM
guthrie&co
Oct 17, 2010 02:37 AM
