Gasket set
Old Dec 30, 2010 | 09:22 AM
Scratcher's Avatar
Scratcher
Gasket set
Ive been looking around for a complete gasket set for an 87 6.9. Hopefully I will be picking up the replacement engine on Monday. Probably wont get it into the truck for a couple of months as I try to take time to do some refurbishments on it. My plan is to change out the oil seals and all gaskets except the head gaskets. Ill probably change the vacuum and fuel pump too. I also plan to start off with a full synthetic oil.
Any good links for gaskets? Particularly the rockers. Should I buy a set or is it better to buy individually?
Old Dec 30, 2010 | 09:29 AM
rodneywar's Avatar
rodneywar
the rockers usually come in a set for like 10 bucks i use felpro hg gasket set form napa that and front cover gasket set from napa as well
Old Dec 30, 2010 | 11:00 AM
kenpobuck's Avatar
kenpobuck
Why not the head gaskets? Since it is out of the truck and easey to get to I would change them as well. Just for piece of mind.
Old Dec 30, 2010 | 01:41 PM
1994F2507.3L's Avatar
1994F2507.3L
i would do the head gaskets too if i were you... you would be pretty aggrivated if you put all the other ones in got in the truck and then the head gasket started leaking....
here is the set from autozone i would go with this one even though it cost a bit more.... ive heard good things about victor rienz gaskets
Victor Reinz/Full Gasket Set (FS3789) | Full Gasket Set | 1987 Ford F250 3/4 ton P/U 4WD 8 Cylinders 1 6.9L Diesel | AutoZone.com
here is the set from orielly made by felpro
List: Engine Kit Gasket Set - 1987 Ford F-250 | O'Reilly Auto Parts
you can also get a kit from international but you have to call them for prices and part numbers ect.... ill be getting my kit from international when i rebuild my 7.3 for the turbo.
Old Dec 30, 2010 | 02:51 PM
Scratcher's Avatar
Scratcher
You guys are right. I think I may go ahead and do the heads too.................. Its gonna be a lot easier to do them on an engine stand.
I cant afford ARP studs but I wont be running a turbo anyway. Should I go for new head bolts or re-use what I have?
Thanks for the useful links
Old Dec 30, 2010 | 06:50 PM
greywynd's Avatar
greywynd
Just reuse them unless you see something physically wrong with them, these headbolts are not torque to yield type bolts.
Old Dec 30, 2010 | 07:08 PM
Scratcher's Avatar
Scratcher
Think I read somewhere that if you re use them the torque values are different?
Old Dec 30, 2010 | 08:34 PM
rodneywar's Avatar
rodneywar
no the torque values are the same
Old Apr 14, 2011 | 08:39 PM
Scratcher's Avatar
Scratcher
Originally Posted by 1994F2507.3L
Just ordered the full set and a valley pan.
Old Apr 14, 2011 | 09:36 PM
BlueOvalBud's Avatar
BlueOvalBud
I used the Victor Reinz head gasket set and valley pan from Carquest 2 winters ago, they are extremely high quality!
Old Apr 14, 2011 | 10:11 PM
84-6.9L's Avatar
84-6.9L
The torque values are different, new is 90 IIRC and used is 100ftlbs
TA455HO
16
Aug 15, 2025 08:15 PM
jjlrrw
63
Nov 18, 2019 07:46 AM
TexinCali
Mar 19, 2014 10:16 PM
Jason6969
Dec 9, 2012 05:50 PM
slow3v
Oct 6, 2011 09:04 PM
