2006 Driver Side Mirror Help
The issue is I need to replace just the mirror part on the driver's side. The black housing is good. This has the mirror glass mounted on a black plastic plate. The plate looks like it snaps into another flat plate that is attached to the power mirror controls. I thought it would just snap off but it loks like it has about 4 finger type clips molded into the back side of the mirror. I tugged at it pretty hard last night but felt like I was going to damage something. Has anyone replaced this mirror face on a 2006 Crew Cab before? Any pictures would be a big help.
Thanks,
Chris
1. This mirror plate has 4 location on the back side with locking tabs that snap onto the mirror motor mounting plate.
2. Each location has 2 platic tabs molded into the plate (8 tabs total).
3. Each tab location is at a 45 degree angle from the center of the mirror. In other words, drawn an imanginary line vertically down the mirror and each tab will be located 45 degrees to the left and right on the top and bottom.
4. I moved my mirror as far inward (toward the truck) so I could get access behind the outside edge of the mirror face. In this position I could see the top and bottom outer tabs
5. I pulled on the mirror with one hand and with the other I used a flat blade screw driver to lift on the tabs until they popped free from the motor plate.
6. After 2 sets of the tabs are free you can wiggle the mirror to get the other 2 sets off.
7. With the new mirror just push back onto the motor plate.
This was not very easy but it was not that hard either. I had to pull on the mirror pretty hard while getting the screw driver behind the tabs. Hope this helps someone else in the future. See pictures below.
https://www.ford-trucks.com/user_gal...id=238642&.jpg
https://www.ford-trucks.com/user_gal...id=238643&.jpg
https://www.ford-trucks.com/user_gal...id=238647&.jpg
