Possible Multiproblems, Can you help??
Old Dec 30, 2010 | 03:34 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by uscav88
I checked the wires didn't see any burnt marks but I'm sure it needs glow plugs
Motocraft ZD-11 glow plugs. They are the Beru mentioned by IABill.
Old Dec 30, 2010 | 06:29 PM
F350-6's Avatar
F350-6
If you're down around 10v with the key on, you're likely dropping too much while cranking. Get your batteries charged up and load tested.
Yes there is a problematic electrical thing under the valve covers, but it's just an electrical plug (that has probably come loose on yours). No reason to be shy about pulling the valve covers. When you do, try cranking the engine and watching to see if all 8 injectors are spitting oil while cranking. Worn injectors will also cause a no start unless plugged in. No glow plugs will still let the truck start when it's warm outside.
As mentioned, starting fluid is a no no. Have you ever heard a pop or miniature backfire when trying to start with the fluid? Check your blowby for compression gasses just to be safe.
Old Jan 7, 2011 | 09:16 AM
uscav88's Avatar
uscav88
Can the injectors be interchanged, meaning, is each injector differant, I think my injectors may be my problem. I just put in my new cps and it still runs like crap, it hasn't shut off on me yet. I pulled the injectors, why I did I don't know but since I put them back it seems to be running worse, so did I put the wrong injector in the wrong slot? Is that possible? and if so how do you know which one goes where? Still waiting for my glow plugs to come in. I only took the injectors out of the drivers side and I thought I put them in the same order I took them out, I don't understand why its running worse.
Old Jan 7, 2011 | 09:20 AM
just another truck's Avatar
just another truck
Check your UVCH connections, check your torque on the injectors, allso re torque your rocker arms while in there.
I am no expert on this, but for the life of me, I can not think of a single reason that you would have to put them back in the same order.
My I ask what the original problem was, and why you are after the injectors?
Old Jan 7, 2011 | 09:50 AM
uscav88's Avatar
uscav88
I just looked at the injectors and two injector's holes face one way and the other two injector's holes face the other way, I wonder if that makes a differance. I'm now after the injectors cause it doesn't feel like its firing right. It will gets a quick burst of power then dies down, it just feels like one or two cylinders aren't firing right.
Old Jan 7, 2011 | 09:58 AM
cj45lc's Avatar
cj45lc
Unplug the injectors one at a time to see which one ain't fireing. Hope you put new o-rings on the injectors when you had them out.
Old Jan 7, 2011 | 10:06 AM
Brother Les's Avatar
Brother Les
Did you get you CPS changed out? Mine died on me like that several times, but only when I went through a large water puddle in a pouring rain, never on a dry day. Moisture was getting passed the seal and causing it to hic-up or die. a little vasoline on the rubber seal helped seal it up tighter.
Old Jan 7, 2011 | 10:07 AM
uscav88's Avatar
uscav88
nope, about to get new o rings cause I noticed one is missing. so if I take the injector out and keep it plugged in, should I turn the key and see if its firing? Sorry I'm a self taught mechanic ha. Would it also be possible I bent a push rod? Just for the fact it feels like its misfiring?
Old Jan 7, 2011 | 10:08 AM
uscav88's Avatar
uscav88
I put oil on my cps o-ring and yes I replaced it with a Ford CPS, I'm pretty sure thats not my problem, I think it has to do with the injectors
Old Jan 7, 2011 | 10:13 AM
Brother Les
Your injectors would cause your truck to run badly (o-ring missing) but they would not cause a full shut down of your truck as if the key was turned off. If the injectors were that bad to 'shut the truck off'.... the truck would have never started in the first place.
Old Jan 7, 2011 | 10:15 AM
cj45lc's Avatar
cj45lc
No leave the injectors in & unplug the wire to it, like pulling a plug wire off a gas job to see which cyl is missing.
Old Jan 7, 2011 | 10:28 AM
uscav88's Avatar
uscav88
great comparisson thanks, the shutting off while running I'm not too concerned with right now, I'm not sure if its still doing it yet since I put in the new CPS. I'm ordering new o-rings for the injectors and going to test the injectors themselves. So far it seems that the injectors are interchangeable? I haven't seen anything to the contrary.
Old Jan 7, 2011 | 11:11 AM
  #28
Brother Les
As for the 'shutting down' you will sheep your pants if it happens going down the interstate and your pulling a load at 70 mph...
(I was hanging onto the Wheel and my wife was screaming bloody murder...)
If you mean are the injectors 'interchangeable' from one cylinder to the next? Do not pull one injector and put it in another cylinder, after being run they Are Not interchageable as they have been 'seated' in the certain cylinder and may/will cause problems if 'interchanged'. Put them back in the same place they came out of.
Old Jan 7, 2011 | 11:59 AM
  #29
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
The Glow Plug relay is fine, I turned the key and tested both terminals, they are both showing around 10v and I hear it click off. I've never replaced the glow plugs myself, its always ran rough so they may all be burned out. They had new ones put in but I don't think they really did it.
If your battery voltage is at 10 volts with the glow plugs on, Have you checked the the voltage while cranking the engine over? 10 volts is too low you may have battery problems. You must have 10.5 volts to operate the pcm, If the voltage is low it will not start. Hook up the volt meter to the batteries to see the voltage while cranking.
Old Jan 7, 2011 | 06:58 PM
  #30
F350-6's Avatar
F350-6
If you pulled your injectors out, you need new o-rings on them like the others have said. If you're missing an o-ring, your truck will not run right. Don't even try to do anything else before you pull the injectors back out and replace the o-rings. Get them from Ford, International, or Alliant Power. Don't get the cheap o-rings from the local parts store.
