cold cranking amps
Old Dec 30, 2010 | 08:32 PM
49fordpickumup's Avatar
49fordpickumup
Look down the carb and see if you are pumping fuel. See if you have spark at the plug. Backtrack on the missing item.
On ground wires. It was suggested to me to attach ground wires from bed to frame, from cab to frame, from engine to frame and front end to frame. Attach the battery ground to either the frame or engine. All truck sections use grounds for some system such as lights, radio/ instruments, engine and lights again. Attach grounds so you can check them occasionally for tightness and corrosion. chuck
Ficken609
Jan 7, 2024 03:20 PM
Jmoen7
Dec 27, 2015 03:00 PM
kelleyboy
Jul 29, 2009 02:39 PM
GSXRF250MIKE
Apr 30, 2009 01:16 PM
bluthunder
18
Feb 24, 2007 10:15 PM
