Airbag Code After Doing Repair
Old Jan 2, 2011 | 12:29 AM
Normmus's Avatar
Normmus
Thank you 03 Maz B23 and projectSHO89 for helping me through this very frustrating repair.
I have located the module behind the passenger side kick panel, and disconnected the connector. I checked the resistance between the P/LB and the BK/W on the plug that connects to the module. Hopefully this is indeed the procedure outlined in post 11. The resistance there is reading 1 Ohm on my meter, well below tolerances. Here is a pic of the plug that I got the readings on. I have to say, that is an awkward place for a 6'6 260 pound guy with bad knees to be working!
If what I did is incorrect please let me know. Oh, a side note, every time I did anything to the air bag system, the battery was disconnected.
Regarding clearing the module, I have not looked into the procedures yet, but I did try the 256 on off thing, which did not get rid of the light. I turned the key on and shut it off after about 5 seconds, 256 times. I am close to insanity due to the dinging!
Old Jan 18, 2011 | 04:49 PM
Normmus's Avatar
Normmus
This is still not fixed, I took it to the garage and they put it on the scanner to clear the code. It picked the code back up again.
I am going to recheck the resistance in the circuit.
There are 2 connectors to the ABDM. Which one has connector C1-18 Circuit 570 (BK/W)?
There is a BK/W on each connector.
Old Jan 20, 2011 | 10:32 AM
Normmus's Avatar
Normmus
I have ordered a shop manual, in the meantime is there anyone who can hook me up with a wiring diagram? The only manual I have is a Haynes and it is horrible.
Old Jan 20, 2011 | 03:40 PM
rioking's Avatar
rioking
wow my airbag light came on one day when I tried turning off the passenger side. didn't know there was any signifiance of the flashes...so I saw this thread and just went to check mine out. it is a 2 and then a 7. which the code doesn't have on it...so now I have to find out what that means...thanks for this thread
Old Jan 20, 2011 | 03:52 PM
rioking's Avatar
rioking
sounds like I have a burned out light bulb...that is the good news..the bad news is it is a 70 dollar bulb.....
Old Jan 20, 2011 | 06:46 PM
03 Maz B23's Avatar
03 Maz B23
If your are refering to bulb in the shutoff switch for passenger airbag get one of these from Radio Shack and solder it in place.
12-Volt Colored Mini Lamps (3-Pack) - RadioShack.com
Old Jan 20, 2011 | 06:49 PM
03 Maz B23's Avatar
03 Maz B23
Can't guarantee they would have it but check reference department of your local library to see if they have any wiring diagrams.
zando
Escape & Escape Hybrid
Dec 15, 2016 09:37 PM
dtherrien
2004 - 2008 F150
Nov 12, 2016 04:40 PM
pdrhodes1
13
Jun 8, 2016 03:22 PM
Rajczak
Jul 9, 2012 05:46 AM
mediumfry
Nov 25, 2003 06:25 PM
