Modular V10 (6.8l)
PROBLEMS WITH 05 V10s
Old Dec 28, 2010 | 08:25 PM
ssg510's Avatar
ssg510
Thinking about buying an 05 v10. Do those engines, three valve, have the spark plug problems. What should I look out for. Thanks
Old Dec 28, 2010 | 11:54 PM
Mr Hanky's Avatar
Mr Hanky
There is a problem with the spark plugs but not the same as the 2 valve. The 2 valve has a problem spitting the spark plugs whereas the 3 valve engine have problems with the lower portion of the spark plug getting stuck in the cylinder head and coming apart. I would look up v-10 3 valve spark plugs on youtube and you will find many videos showing this problem and how easy it is to correct with the right tools. By the way not all v-10's have this problem. I replaced my plugs at 65K and had no problems....
Old Dec 30, 2010 | 09:39 AM
bowtied_micky's Avatar
bowtied_micky
When I changed the plugs in my 06 5.4 I soaked them in penetrating lube for 2 days and still broke 3 off.
If you are buying the truck from a dealership I would make new plugs part of the deal. I would actually go buy the one piece champion plugs and have those put in rather then the motorcraft plugs.
If you are buying it private party I would order the broken plug removal kit and have it on hand if necessary. If you don't use it send it back, if you do use it you can either keep it or sell it to someone here used and get most of your money back.
micky
Old Dec 30, 2010 | 06:26 PM
mwsF250's Avatar
mwsF250
The latest Motorcraft/Autolite plugs are one piece as well.
The problem gets worse with miles and low quality fuels. I have not yet heard of any plugs breaking if changed every 50K.
Old Dec 31, 2010 | 06:19 AM
scraprat's Avatar
scraprat
Top Answer: 5
I changes mine in the '08' @ 100k with no problems, but let them soak for a short bit with PB Blaster first.
Old Jan 1, 2011 | 03:55 PM
ssg510's Avatar
ssg510
Thanks for the help guys. My truck has about 32000 on it now. Don't know if I should change them now or at 50K.
Old Jan 1, 2011 | 05:26 PM
halvy's Avatar
halvy
Hey guys, am I just lucky or what. I have a 99 E350, V10 which I bought new and have changed the plugs at 100M, 200M and 300M, with no problem betting them our or blown out.
Old Jan 1, 2011 | 05:27 PM
halvy's Avatar
halvy
Correction, I have an F350, not E350.
Old Jan 2, 2011 | 09:10 PM
Veetener's Avatar
Veetener
Well, I have an *E350* a club wagon 15-pass. It's a 1998 with about 125K. I bought it used 5 years ago from a dealer and I must add, they must have done a complete tune cause my baby drove for five years before I decided to get it tuned. And it was done only because I was planning a trip to Utah from CA. Other than the tune and oil change every 3K it has had no other work. Oh, the original Motorcraft battery finally went to battery heaven. btw, prior to the tune the engine was running smooth as silk, no vibration, no noise, no anything. I did it 'cause I thought it was due because of the mileage.
I love my V-10! The most practical, efficient, comfortable, and powerful engine I've ever owned.
Eddie
Old Jan 7, 2011 | 09:03 AM
captchas's Avatar
captchas
Guest
yes the new plugs are all one piece,
the old ones if not very slowly abd carefully removed in a back and forth manner would snap off.
install the new ones with some never sieze on the threads,use atorque wrench to be sure they are properly tightened and not over tightened.
kynnhoj
Engine Swaps
Nov 18, 2009 12:47 PM
Husky44
Nov 14, 2009 11:58 PM
mizzitch
Modular V10 (6.8l)
35
Jan 10, 2007 01:32 PM
someday
Jun 26, 2005 12:01 PM
RUBICON
Computer Chips & Tuners
Mar 21, 2005 02:50 PM
