6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Mini Maxx installed last night
Old Dec 28, 2010 | 05:17 PM
RM2738's Avatar
RM2738
I bit the bullet and installed my H&S Mini Maxx last night after months of deliberation. All I have to say is WOW. Power is great, response is amazing, zero turbo lag. Just absolute amazing performance.
I installed the S&B CAI with oiled filter, stainless CAT/DPF delete pipes and of course the tuner. My lie-O-meter says I averaged 26.7 mpg on the way to work this morning, which I know is BS, but man, it sure made me feel good. Will update once I run this tank down.
Total install time was about 2 hours for the intake and pipes. plus the download time for the tune.
For anyone considering a DPF delete, I'm a supporter 100%.
Old Dec 28, 2010 | 05:21 PM
RM2738's Avatar
RM2738
Couple Questions:
What's a safe EGT range?
Max boost?
Are traction bars recomended on a stock height truck to prevent axle wrap?
Old Dec 28, 2010 | 06:35 PM
pyro2nite's Avatar
pyro2nite
I won't run mine above 1350 for the egt. As for the boost, 40 and below would be safe. Of course if you hold it at 40 your egts will climb fast. If you run the hot damn tunes you should get traction bars
Old Dec 29, 2010 | 11:36 PM
LaredoF350's Avatar
LaredoF350
With the cat and dpf deleted, do you still have a muffler? Hows the sound?
Old Dec 30, 2010 | 05:54 AM
RM2738's Avatar
RM2738
Muffler is still on. It sounds great. It reminds me of a jet engine.
Old Dec 30, 2010 | 06:57 AM
R-T0r21on's Avatar
R-T0r21on
That "muffler" is nothing but a can. You can look right through it. The DOC/DPF does all the "muffling". I like the sound too. Nothing like a powerful diesel engine breathing and sounding like it should.
Old Dec 30, 2010 | 08:12 AM
RM2738's Avatar
RM2738
Old Dec 30, 2010 | 08:27 AM
longview1's Avatar
longview1
Banned
Oh, Welcome to the "Bubble" all of us dpf deleters live in...
Old Dec 30, 2010 | 09:03 AM
LaredoF350's Avatar
LaredoF350
I see in your sig thay you are running MBRP. How would you describe the sound of it vs just the DPF/DOC delete?
Old Dec 30, 2010 | 10:50 AM
R-T0r21on's Avatar
R-T0r21on
I can't really tell you for sure. I got the MBRP as a DPF back unit. I did the delete much later. It sounds really nice to me from the rear when I walk behind during idle. It's all "even" sounding, as opposed to being all on 1 side.
Old Dec 30, 2010 | 06:01 PM
RM2738's Avatar
RM2738
Can anyone thing as to why my cruise control wouldn't work after Mini Maxx install?
Old Dec 30, 2010 | 06:10 PM
aquaman's Avatar
aquaman
I seem to remember seeing a TSB that fixes the cruise control from turning itself off even on early 2010 builds (but applies only to manual trannies).
That makes me wonder--all of these tunes must have been based on some earlier version of the PCM code at one point. I don't think it's simply overwriting just the cal tables...or is it?
Old Dec 30, 2010 | 07:32 PM
onthefence's Avatar
onthefence
I am interested in buying a super duty. Can anyone give me some input on the 6.4L powerstoke. I'm a former dodge owner and want some opinions on this engine. Are they reliable, looking at an 08 and an 09
Old Dec 30, 2010 | 07:40 PM
R-T0r21on's Avatar
R-T0r21on
Don't have any experience w/ the Mini Maxx. Any codes? Maybe EGR disabled, maybe brake light switch. Grasping at straws though.....
Old Dec 30, 2010 | 07:55 PM
senix's Avatar
senix
I have an 08 with the 6.4.
It is a good motor depending on how you would use the truck. So lets start there.
What type of use and loads or towing would you expect it to do?
