electrical starting probem
Old Dec 28, 2010 | 03:45 PM
beersy50's Avatar
beersy50
This morning I went out to start the truck to go to work and it acted like the bats were dead I knew this wasn't the case because I have an on board battery charger and it was pluged in. so I poped the hood in attempt to start from under the hood by shorting the relay. the small guage wire that acts as a ground for the relay had melted into two peices. So i grabed a larger guage wire with to gator clips (temporary of course just to get me to work) and cliped it on to the neg terminal then touched it to the starter relay and then I heard the glowplug realy start clicking. as soon as i started to spin the engine the (probably 10 or 12 guage) wire melted. I stoped there and took my wifes eqinox. Whats going on? How come I all of a sudden have this issue. the battery terminals are clean in case that was someones first thought.
Old Dec 28, 2010 | 07:38 PM
farmert's Avatar
farmert
I would check the ground cables where they bolt to the engine. It sounds as if they are bad and when you go to start it is trying to compleat the circut threw the small wire. I had a 86 gasser that the ground from the battery broke at the block connection, and it melted the body grounds when trying to start it.
Old Dec 29, 2010 | 04:09 AM
beersy50's Avatar
beersy50
Thanks I'll start there
Old Dec 29, 2010 | 12:54 PM
PLC7.3's Avatar
PLC7.3
Did you attempt to start by key operation?
Do you have a tilt steering wheel?
Normally the starter relay is screwed to the fender for a good ground.
Old Dec 29, 2010 | 06:48 PM
beersy50's Avatar
beersy50
plc7.3
Yes
No
And that fender i rihno lined the whole thing except the painted surface this summer. I do belive that it is a ground issue because i put a set of jumper cables on the neg side of the bat and the other end on the top alternater mount and it spun right over. how many grounds are there? I found two but I can't see where they attach to the block?
Old Dec 29, 2010 | 07:12 PM
rodneywar's Avatar
rodneywar
one is right next tot the fuel pump and the other is under the powersteering pump they are attached to the corners of the block
rodneywar's Avatar
rodneywar
easiest way to see em is from underneath not the top
