Turbo
Old Dec 28, 2010 | 02:20 PM
JC41's Avatar
JC41
Turbo
What is the best turbo to purchase for stop and go situation, plowing snow & towing?
Old Dec 28, 2010 | 02:40 PM
gearloose1's Avatar
gearloose1
Honestly?
A roots belt driven supercharger.
Old Dec 28, 2010 | 03:15 PM
JC41's Avatar
JC41
Really I'mjust tired of buying a new one every year or so because of the viens sticking
Old Dec 28, 2010 | 03:29 PM
Sullid01's Avatar
Sullid01
there is a great write-up in the tech folder on how to clean and refurbish your turbo for about $125 in parts. I am planning on trying it soon.
I have been interested in the answer to your question as well, and so far I'm not sure there is a good answer. It seems that most of the other turbos available are really meant for performance. A non-VGT turbo might solve the vane sticking problem (they have no vanes)- they are expensive and for the most part all about performance.
Old Dec 28, 2010 | 04:17 PM
gearloose1's Avatar
gearloose1
If you clean the rust out good, and exercise it once a month, it will not come back ... that is what i did.
Old Dec 29, 2010 | 12:52 AM
flamebuster's Avatar
flamebuster
You might check with Tex25025; He changed to a 64mm turbo. But I can't remember all the details involved. Still it might be the answer your looking for..
Old Dec 29, 2010 | 03:41 PM
smokersteve's Avatar
smokersteve
Get a non VGT turbo that is smaller than 64mm from elite diesel, ats or rcd
Old Dec 29, 2010 | 04:03 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by gearloose1
Honestly?
You can't be serious
Old Dec 29, 2010 | 04:42 PM
davidkstyler's Avatar
davidkstyler
Technically that is correct. Turbos are best at constant speed. They do not accelerate well resulting in "turbo lag". They are great for generators, highway trucks, etc.
A belt driven blower does rob some power from the engine but gives an instant response. If you are constantly changing speed, such as when snow plowing, it might be a better solution.
Can you get a belt driven blower for the PSD? Probably not enough room without cutting the hood!
Old Dec 29, 2010 | 04:57 PM
tex25025's Avatar
tex25025
For stop and go, I wouldn't suggest a 64mm turbo unless he is really going to go lower in gearing(min. 4.30 gears).
Now for towing, you can't beat the 64mm turbo. It's great. Hauls consistently well for ~16k worth of horse flesh. "Holds" egts very well around the 1050-1100°F range. Bad thing is that it isn't for the faint of heart when it comes to modding the vehicle.
I would suggest non-vgt, but at the very least that's going to require a tuner to let the computer know not to look for a VGT input.
Old Dec 29, 2010 | 05:17 PM
gearloose1's Avatar
gearloose1
If you want to really geek out, you can have a small roots doing boosts instantly, feeding it into the turbo for second stage...
A better solution than twin sequential turbos that are still not as fast.
Geeze.. what did I just talk myself into???
Old Dec 29, 2010 | 05:27 PM
davidkstyler
Please post pictures!!!!
Old Dec 29, 2010 | 05:30 PM
gearloose1's Avatar
gearloose1
On a E van, the turbos will have to be in the Passenger seat!
Old Dec 29, 2010 | 06:36 PM
cheezit's Avatar
cheezit
a set of compounds with a blower has been done on a 6.0.
Old Dec 30, 2010 | 05:10 AM
npccpartsman
How much do you actually drive this truck and does it sit for long periods of time?
