The red brake light on the dash of my '86 f250 won't go off. I don't know what the deal is. MY e-brake isn't on or stuck. The pedal does seem to be a little mushy. And I have to push pretty hard on the pedal to come to a complete stop. what's this an indication of? I havn't found any brake fluid on the ground, so I'm almost sure it's not leaking. There is, however, some bubbling on the paint of the booster where it meats the mast. cyl. Could there be a leak here? I really don't know what I should be looking for here.
I had the same problem with my 85 truck. I replaced the master cylinder and that fixed the problem. I had a little leaking around the master cylinder and that was fixed when i put a new one on.
I went out and checked the fluid in the reservoir this morning and only the front portion seems to be low. Could there just be air in the lines and bleeding could be the answer?
I just went through this myself. The small front reservoir is the rear brakes. The large rear reservoir is the front brakes. My pedal got low, and the small reservoir was empty. I didn't see any leaks out of the back wheels, or along the frame, so I refilled it and bled the rear brakes.
A week later I checked it again and it was getting low. I pulled both rear wheels off to make sure the wheel cylinders weren't leaking, and checked the rear lines again. I noticed too that there was a little dampness on the booster, so this was the only place the fluid could be going. I replaced the master cylinder and everything is fine now.
Do a little troubleshooting and you will eventually find the problem.
Screw the trouble shooting. There's Brake fluid on my floor boards now! However, I think I know what the deal is. Back up under the dash there is and pneumatic emergency switch for the brakes on a fifth wheel trailer. (previous owner used to haul cattle around) Well, I think that the fittings have come loose back around there. (I hope) if so, it'll be a pretty simple fix I think. JUst pull the unit and the lines out and plug the fittings that are attatched to the M/C. KNow what I mean. HOpefull this will do the trick. Any other thoughts on how B/F could be inside the cab on the floor boards?
Well, I was right. It was that pneumatic emergency fifth wheel brake switch. OVer the last fifteen years the brake fluid has coroded all the rubber and plastic seals. BUt I still don't have any pressure behind the peddal. I bet there's air in the line. Will probably have to bleed them. What's the process? Start with the rear passenger side, then to the other side, passenger front, then driver's front? Is that how it goes? Now I just need to find someone to push the brake pedal while I take care of the lines.
Cross your fingers and hope you don't break any of the bleeder screws off(very easy to do). I did this, and ended up trying to bleed it by loosening the brake line. Not totally satisfied, I replaced the wheels cylinders in the back. Not a bad job on a F150, but if you have a full-floating rear axle, I hear it's a pretty big job. And when you go to change the wheel cylinders, the brake line may be frozen to the nut. I had to replace the lines from the wheel cylinders to the rubber hose/tee fitting.
