TPMS warning indicator issue
Old Dec 28, 2010 | 09:28 AM
Champ198's Avatar
Champ198
Hi everyone,
during the dealers attempts to solve my hop at 50mph, I believe they put wheels from another truck on my truck. The TPMS sensor has been putting warning messages on my dash everytime I start the truck. Air pressure is 60+ in each tire. The dealer will reset it and it will be fine for a day or two, then the warning will come back on.
is there anything I can do at home to reset it myself?
Old Dec 28, 2010 | 01:01 PM
rocdril's Avatar
rocdril
Yes, check the manual, it will tell you how step by step. While you are doing it, the message center will walk you through it. I was having the same problem for awhile. It took me a couple times to figure out. My truck calls for 65psi front and 80psi rear. Make sure you set your pressures correctly.
Old Dec 28, 2010 | 07:35 PM
zcellis3's Avatar
zcellis3
Sounds like you need more air in the rear tires. Pump them to 75-80psi and see if the message goes away.
Dude Lebowski
2009 - 2014 F150
27
Nov 19, 2013 03:45 PM
SuperDutyScaler
15
Jan 11, 2013 07:27 PM
nut1605
6.7L Power Stroke Diesel
Dec 4, 2011 10:17 PM
hhansen59
Jul 19, 2011 08:57 AM
