12 volt vs 24 volt Winch
Old Dec 28, 2010 | 06:26 AM
Scorpion2's Avatar
Scorpion2
I have the dual alternator, dual battery 6.7 and was wondering if anyone has installed a 24 volt winch? If yes, what did you have to do to support the 24 volts?
Old Dec 28, 2010 | 07:26 AM
ruschejj's Avatar
ruschejj
I have a 12V winch inside a trailer that we use to pull stuff up the ramp and inside with. It's a Warn and it's a big one (12K or larger). That thing will pull incredibly hard so I'm not sure what a 24V winch would do. Seems like a lot of power that is not so much needed.
Old Dec 28, 2010 | 07:36 AM
boats313's Avatar
boats313
If you go with 24v, wouldn't it need it's own power system? The alternators are 12v and the dual batteries are wired in parallel. I don't know how you could get 24v out of the truck, but of course I'm no electrician either.
Old Dec 28, 2010 | 09:22 AM
porthole's Avatar
porthole
2 more batteries wired in series, 24 volt charger (there are marine versions available), inverter large enough to power the charger (again marine version). Seems like you'll also need to through in a bed tool box too for the extra batteries, charger and inverter.
I'd say your looking at about $1500 before you buy the winch
Old Dec 28, 2010 | 09:23 AM
gearloose1's Avatar
gearloose1
It comes down to cost, and why you want / need another subsystem on your ride to maintain.
Old Dec 28, 2010 | 09:30 AM
Rickx's Avatar
Rickx
Do you have PTO ready option? Hydraulic Winches are better if you have a way to run them.
Old Dec 28, 2010 | 09:38 AM
porthole's Avatar
porthole
Don't need a PTO for that. We put a power steering powered hydraulic winch in a buddies F-250. That was an awesome winch, complicated compared to two battery cables, but it could pull the frame out from under the truck!
Old Dec 28, 2010 | 09:58 AM
sncbluegt's Avatar
sncbluegt
Originally Posted by porthole
Don't need a PTO for that. We put a power steering powered hydraulic winch in his F-250. That was an awesome winch, complicated compared to two battery cables, but it could the frame out from under the truck!
I always wanted a hydraulic winch...The Mile Marker was my choice..but I had heard that they make the power steering pumps wear out fast.
Old Dec 28, 2010 | 10:07 AM
Scorpion2's Avatar
Scorpion2
I have the PTO option, but it seems like it would be more expensive and a pain. I think I'll just go with the 12 volt version.
Old Dec 28, 2010 | 11:35 AM
Rickx's Avatar
Rickx
Definately more expensive and more of hassle to setup. But thats probably what I'll do on my truck.... eventually.
Stangas
Oct 17, 2013 10:58 PM
BLACK 6
Electrical Systems/Wiring
Sep 21, 2012 09:45 PM
iggybob44
Mar 15, 2009 11:10 AM
mazdaboy873
1983 - 2012 Ranger & B-Series
Jan 21, 2004 06:36 PM
78bigunns
Garage & Workshop
Nov 18, 2002 02:32 AM
