4.0L engine flush cleaner???
Old Dec 27, 2010 | 10:47 AM
FordHubby's Avatar
FordHubby
My sisiter has a 10-15 yr old 4x4 Ranger with a 4.0L. The oil has not been changed in several years. Recently it has started "tapping"( 3 qts low). I haven't heard it so I don't know if it's a rod or lifter. "SOmeone" told her it needs an oil pump. Their budget is SEVERLY limited(virtually nonexistant). I thought about changing the oil and filter 4-5 times in 1 day with a good warmup in between changes. DOes anyone have any ideas? ALso is it possible to drop the oil pan and replace the pump without pulling the engine?
Old Dec 29, 2010 | 01:29 PM
Beechkid's Avatar
Beechkid
1st, i would change the oil/filter, then check for noises, if no diagnostics were done on the oil pump, then if you had any doubts, connect a mechanical gauge in place of the electric sending unit, check it..it's probably ok. I would avoid flushes at this point (since if there is a crud buildup it could easily break a chunk loose and cause real problems), just check the oil weekly for level, visual cleanliness and change the oil as needed.
