Sponsored by: Auxito
Fuel Filter
Old Dec 26, 2010 | 10:12 PM
peters73's Avatar
peters73
Fuel Filter
Stupid question, how hard is it to replace the fuel filter on the 03 with a 4.6. Do I have the purge the fuel lines and how do I do this? Thanks
Old Dec 27, 2010 | 12:51 AM
phil6608's Avatar
phil6608
You need a fuel line tool. No need to purge the system.
Just be careful, have plenty of rags and ware some eye protection when you do it.
It's a good idea to let the truck sit for a wile before doing it. So the fuel system is not fully pressurized.
Old Dec 27, 2010 | 10:16 AM
chaser1602's Avatar
chaser1602
look for the schrader valve on the fuel rail.You can releave the pressure there. Dont forget the rags and ppe,put a drain pan under it. You can get the tool were you buy the filter for a couple $$$
Old Dec 27, 2010 | 04:08 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
I've been changing this style/type of filter on F150s for over 10 years now.No need to purge or let it sit.Just wear some safety glasses and have a rag or 2 available.I have it down to 5 minutes or less on my current F150.
Old Dec 27, 2010 | 04:17 PM
peters73's Avatar
peters73
I'll just have to get the tool. I just bought the truck like 3 months ago, it has 170K on it. I have no clue of when the fuel filter was changed before. I also need to flush the radiator. I thought about taking it to a shop and have it done.Thanks,Mark
Old Dec 27, 2010 | 08:09 PM
makomark's Avatar
makomark
Be a good idea to flush the brake fluid and power steering fluid, too.
Old Dec 27, 2010 | 08:13 PM
peters73's Avatar
peters73
I just had the brakes done and they were bleed.
Yes, I need to flush the power steering unit. I have an add for $69.00 bucks to get it done. Is there a easy way to flush the PS?
Old Dec 27, 2010 | 09:41 PM
kaboom10's Avatar
kaboom10
I bought a turkey baster and sucked out what I could then filled it up with full synthetic trans fluid. Did this till it was clear and it took only a quart to do it. Better power steering and no noise.
Old Dec 27, 2010 | 09:56 PM
peters73's Avatar
peters73
I think I might have to try this, lol. You kept doing this process until the fluid was clear? Did you drive it for a couple of miles and sucked the oil out again?
I have seen in-line filters for the power steering.
Old Dec 27, 2010 | 10:13 PM
kaboom10's Avatar
kaboom10
Just cycle the steering wheel from lock to lock. Put a filter in the return line for max protection. There's a cleaner you can use before changing fluid to.
Old Dec 27, 2010 | 10:15 PM
peters73's Avatar
peters73
Awesome, thanks! I have the turkey baster.....lol
Old Dec 27, 2010 | 10:18 PM
peters73's Avatar
peters73
Also, which line is the return line?
Old Dec 27, 2010 | 10:23 PM
kaboom10's Avatar
kaboom10
Can't remember but it is a low pressure hose. The high pressure hose will have metal screw in ends.
Old Dec 27, 2010 | 10:25 PM
peters73's Avatar
peters73
Ok, cool. Thanks
