CMP oil leak
Old Dec 25, 2010 | 01:39 PM
Piolet's Avatar
Piolet
CMP oil leak
I have an oil leak at the front drivers side of the engine, right about where the cam position sensor appears to be on engine layouts I've seen.
Is this something that can be tightened, or can an o-ring be replaced, or do I need a new one?
I supposedly got a new one about 20,000 miles ago when I had studs, egr, oil cooler, headgasket etc work done.
Engine is 2003 6.0l with 210,000 miles.
Old Dec 25, 2010 | 10:00 PM
cheezit's Avatar
cheezit
you can get an o-ring kit for them
Old Dec 25, 2010 | 11:33 PM
holdendaniels's Avatar
holdendaniels
Easy to fix, get the o-ring kit, remove the bolt replace the o-ring, put back the sensor.
