Misfire from Hell!
Old Jan 21, 2011 | 09:05 AM
NemesisNJ's Avatar
NemesisNJ
Ok, got the plug out a week or so ago, and finally with an extractor tool from Lowes, was able to get the thread repair coil out, yesterday. I have since ordered, the Time-Sert Ford Plug Repair Kit, for a staggering $363, but it's that or new Heads, which I'm not dropping $3K on. Everyone who saw the pic said it was deff running way too lean, so I'm gonna check for vacuum leaks and clean the MAF Sensor as well and then the EGR valve. On top of that I'm gonna pick up a Compression tester, so I can test the cylinder, and a Noid Light to test all the fuel injectors, hopefully I can replace the fuel injectors this summer as well as all the COP's.
Old Jan 21, 2011 | 08:19 PM
Man_tlac83's Avatar
Man_tlac83
Well its good to hear that your sticking with and making it work. I can understand you frustration with all this. Besides all these problems, you can tell you love your truck. Thats a lot of TLC you been giving it. Keep up the good work on loving your truck.
_____________________________________________
98 5.4 Eddie 4x4 176K
88 Stang 5.0 HO (stock for now)
95 Mazda Protege Dx 1.5L Rotory 5spd 222,252 miles
Old Jan 21, 2011 | 10:33 PM
NemesisNJ's Avatar
NemesisNJ
Yeah it has been quite the headache I will say that. Once I get the truck on the road again, gonna swing by my local trans shop, and have them replace the rear axle seals, and transfer case seals as well, just gotta find a day it doesn't snow in NJ to do it. And then I can tackle a new valve cover gasket as well, since my truck is bleeding oil. Summer project is to pull all the fender flares off, which are gray and weld all the clip holes, and debadge it, and weld those holes and get a new paint job, my paint is horrible. Just need to find new window sills all the plastics under the windows are starting to pop off, no idea where to look for those. Thanks for all the help too!!
RL7
1997 - 2003 F150
25
Jan 6, 2025 02:15 AM
The Hooligan
Nov 29, 2016 01:33 PM
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
Mar 12, 2016 08:51 PM
_Rick_
Jul 19, 2015 10:28 AM
Todd Fuller
23
Aug 11, 2014 12:31 PM
