1978 - 1996 Big Bronco
steering help please asap
Old Dec 24, 2010 | 09:08 AM
miottimouse's Avatar
miottimouse
good day i am looking at buying a 79 bronco and in seeing the steering box is on the out side of the frame in front of the axels with the steering shaft/knuckle set up my question is will a tilt or non tilt steering columm from a 78/79 2wd pickup fit? with or without mods? the reason i ask is this bronco has some issues with the coller/shift parts inside and i would like to just change it out if i could [i dont have the truck yet in the prossess of making the deal] also is the motor/ralated parts for the rear tailgate glass available? thank you regurds joe
Old Dec 24, 2010 | 10:33 AM
g_k50's Avatar
g_k50
ASAP answer is yes.
to both questions.
Old Dec 24, 2010 | 10:48 AM
miottimouse
k 50 thank you so much for the fast info i will now buy that truck and i suspect i will be in this forem also regurds joe
