5 speed swap
Old Dec 23, 2010 | 10:16 PM
m8094538's Avatar
m8094538
5 speed swap
been gone for a bit but now im working on the truck again got pissed off at it and had to leave it alone for a few days haha. first of all i screwed up the c6 2 weeks ago slips now. so i picked up the zf5 today now just gotta go to the junkyard and get what i need for it. i know im going to need a cross member (will one from a gasser f250 work from the 87 or newer trucks mines an 86) i know i need pedals i think they got some from my body style there, a driveshaft (ive never seen an f250 without a midshift bearing till i got my truck is this normal), steering colum, clutch master and slave cylinder and lines( can i use this from a gasser f250), clutch and flywheel(whats the best set up to use to be as stong as possible). if theres anything im missing plz let me know so i can finish my list. second i need to get my new ip to quit leaking and the truck to run right, ive been trying to do this for about a week now and im to the point i may just take it to a shop just to get it back on the road bein as i got a ride to work till the end of january then im on my own. anyway thanks for any help and merry christmas to everyone
Old Dec 24, 2010 | 02:33 AM
91dirtydiesel's Avatar
91dirtydiesel
Where is the ip leaking?
Old Dec 24, 2010 | 06:13 AM
m8094538's Avatar
m8094538
from the injector lines ive pulled it off four times trying to get them right just cant seem to do it, plus i tried turning the fuel up but it still feels lean as hell, now i dont really wanna roll coal but i know i should see alittle something from a dead stop up a hill and i get nothing. i turned it up 4 flats but i was thinkin maybe pensicola just turned it all the way down??? and after 2800 rpm the engine vibrates it did it with the old ip at 2000 or more so it atleast got better. i figure maybe timing needs to be set or its not getting anough fuel. im gonna try again working on it tomarow but if i cant get it right then its goin to the shop. thing is it didnt leak till the day after i first did the ip
Old Dec 24, 2010 | 09:57 AM
91dirtydiesel
Same thing with the leak happend to me. Is it from the hard lines? Or the the middle of the injector, where the return lines run?
Old Dec 24, 2010 | 10:05 AM
m8094538's Avatar
m8094538
it comes from one of the bottom too injector lines on the pump the problem is i cant see it so im not exactly sure what one. i dont see any one my return lines leaking or any leaks around my injectors. ive tried sticking my hand down there to see if i can feel any wet spots but no luck
Old Dec 24, 2010 | 10:09 AM
joe f350's Avatar
joe f350
did u use any tape on the injector threads of is it metal on metal
Old Dec 24, 2010 | 10:11 AM
m8094538's Avatar
m8094538
metal on metal the way they came apart
Old Dec 24, 2010 | 10:15 AM
joe f350's Avatar
joe f350
ok what condtion of the ruber gasket in side the ruber lines
Old Dec 24, 2010 | 10:21 AM
91dirtydiesel
When mine did that I just kept re seating them and after 2 or 3 times I had no leak
