If you put 2 parallel sets of 470 Ohm resistors in series, you get a 940 Ohm resistor.
I used a meter to verify it. I got an ohm reading of 463 end to end. I didn't pull up any formulas because that was easier. I was curious about how much current is going to ground when the AIH is activated. I figured solving for I in ohms law it would be 12v/470ohms. Which would give you .0255. I guess that would be in amps.
