Sponsored by: Real Truck
62mm Or 65mm
Old Mar 4, 2003 | 05:01 PM
info_napl's Avatar
info_napl
Question 62mm Or 65mm
I am going to buy a throttle body. Which would be better 62 or 65. On the larger one to I have to change anything.
Old Mar 4, 2003 | 05:03 PM
V10KLZZ71S's Avatar
V10KLZZ71S
62mm Or 65mm
BBK PART # 1711 15 MIN INSTALL 65 MM
Old Mar 4, 2003 | 05:24 PM
tankhead's Avatar
tankhead
62mm Or 65mm
go w/ the 65mm. same install as my 62MM I would think.
Old Mar 4, 2003 | 09:27 PM
JPS's Avatar
JPS
62mm Or 65mm
What kind of performance increase does this bigger throttle body give you? Are you guys actually getting a "seat of the pants" experience, or is it a cumulative effect with other add- on's? I have bee kicking the chip idea around and really haven't heard anything about a bigger throttle body. Anyone..... Anyone?
Old Mar 5, 2003 | 04:14 AM
V10KLZZ71S's Avatar
V10KLZZ71S
62mm Or 65mm
I installed mine about the same time as my MICROTUNER,actually one day apart. It sure did feel stronger after tb install,i recomend!
Old Mar 5, 2003 | 09:30 AM
tankhead's Avatar
tankhead
62mm Or 65mm
Can't give u any comparison on the throttle body alone because I installed it at the same time as the headers, throttle body spacer and cat-back. If u get one and look at em in a side by side comparison.
Old Mar 5, 2003 | 07:21 PM
Quikirk's Avatar
Quikirk
62mm Or 65mm
What exactly does a larger throttle body do, mechanically I mean?
Old Mar 6, 2003 | 05:16 PM
4x4x4x4's Avatar
4x4x4x4
62mm Or 65mm
It is a larger opening that will allow more air to be ingested by the engine.That is if the engine is capable of pumping more air than the factory throttle body will allow.
Things that could cause this are exhaust,headers,larger valves,supercharger and such.
Old Mar 6, 2003 | 09:28 PM
Quikirk's Avatar
Quikirk
62mm Or 65mm
Thanks Steve
