I added dome aux lights to my 2011 F250.Up front I have 2 Hella 500FF driving lights hooked up to one of my upfitter switches.Out back I have 2 aux reverse lights hooked to another one of my upfitter switches.And inside the cap I have 2 more lights that are mounted to shine into the cap or they can be flipped back to shine out of the cap these are wired to thier own switch inside the cap.
I love it! I have 4-50 series kc lights that I'm working on a custom bracket using the existing bracket holes to mount 2 driving lights and 2 fog lights between the tow hooks. I'll be sure to post once I'm done. Again, looks great!
Oooh I like those lights up front! What did you bolt them to?
I used a right angle drill and drilled right through the inside of the bumper just far enough back so the bolt stick down behind the plastic skirt on the bottom of the bumper.
The rev lights are hooked to one of my upfitter switches and the lights in the cap are tapped into the battery wire for my 3-12V outlets in the cap and I just wired in a switch.There is a constant 12V in the cap
Good idea! I might put 4 up there since I don't have the front plate.
I added a pair of LightForce fogs outboard and a pair of LightForce road lights in the center. I had nothing but problems with Hellas, went through about 3 pair, all with shattered lenses from rocks. I have a pair of cheap fog lights under the trailer hitch as backup lights.
