The 8 lug wheels have an 8 on 6.5" bolt pattern, which is pretty much standard on a 3/4 and 1 ton up until 99(Ford went Metric at that point) For a Ford, Ford and Dodge wheels will work, as, the pilot home is too small in Chevy wheels to fit over a Full floating axle's hubs other than the 14 bolt. If you have a semi-floating rear end, any 8 lug wheel you find can be used.
Evan
