Stuck in Low Range
Old Dec 22, 2010 | 12:07 AM
VegiePower's Avatar
VegiePower
Stuck in Low Range
I was backing into the driveway tonight and put it in 4 low (automatic from **** on the dash) in order to get over a snow drift and not ram into the house. When I went to move it I didn't wait for the glow plugs to finish their job and so it didn't start. I heard a "popping" sound from the rear passenger area and actually thought it was my wife banging on the rear of the truck so I got out to look, but no wife there.
So I got back in, waited for the glow plugs to finish and then it started right up. I switched back to 2 wheel drive but the 4-low did not disengage. So I moved it around a bit and ended up driving around the block, doing some stops and driving in reverse for a few feet etc. However, it remains in 4-Low. I have restarted it, switched it back to 4-Low, 4-High, 2-High etc.
Any ideas what is wrong and how to fix it? Perhaps the popping was incidental but I thought I would mention everything.
It is a 2002 7.3L diesel Excursion.
Thanks
Torie
Old Dec 22, 2010 | 01:19 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
to go in/out of low you need to be in N and your foot on the brake. it should go right in/out if not one thing i'd check is your brake lights because i think it uses the brake light sensor on the pedel to know when your on them or not. or i could be toatly wrong but its my guess haha hope it works!
Old Dec 22, 2010 | 01:20 AM
jh818's Avatar
jh818
Might have something to do with the vacuum lines I think. Is your fan stuck in defroster?
Old Dec 22, 2010 | 01:30 AM
Skip1970's Avatar
Skip1970
maybe you should check underneeth the excursion to see if your wife is stuck under there by the transfercase and maybe jammin the 4 low.
Old Dec 22, 2010 | 11:07 PM
VegiePower's Avatar
VegiePower
Thankfully no wife underneath...
What I didn't realize is you have to step on the brake while in neutral to shift out of low range. What I wouldn't give for the owners manual. Thanks for your ideas.
Torie
Old Dec 22, 2010 | 11:23 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
so that did it? if so i'm glad we could help
Old Dec 22, 2010 | 11:26 PM
VegiePower's Avatar
VegiePower
yes sir. Thanks.
Old Dec 22, 2010 | 11:49 PM
Skip1970's Avatar
Skip1970
so to put it in 4 low you need to be in neutral also? and step on a brake?
Old Dec 22, 2010 | 11:52 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yes.........
Old Dec 23, 2010 | 12:44 PM
dchamberlain's Avatar
dchamberlain
Here is a link to get Owner's Manuals What will you give me for it?
https://www.flmowner.com/servlet/Con...ionalEventPage
Old Dec 23, 2010 | 08:34 PM
VegiePower's Avatar
VegiePower
Unbelievable!!! Thanks so much. I have been trying to find the diesel supplement. Guys are selling them on ebay so I am amazed and this find and your generosity. How about my undying gratitude?
Cheers,
Torie
2002 7.3L Excursion Limited on WVO using Plantdrive.ca
GJWallace
Apr 8, 2016 08:13 PM
dkrimetz
Apr 6, 2016 11:37 PM
Bryan Hagan
Feb 27, 2016 01:38 AM
trekbasso
Jun 30, 2015 12:14 PM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
