Hekp, no third gear!!
Old Mar 4, 2003 | 01:30 PM
JohnAC's Avatar
JohnAC
Well the manifold and new carb run smooth. But somewhere i missed something and I now have no third gear. All the basic vacuum lines are hooked up (brake booster, advance, and pvc). Is there an additional line that needs to be hooked for the trans to use third gear?
Whats the best way to set the kick down adjustment? I set the screw to about half way. It does not touch until the throttle is about 3/4 wide open.
86 f350, 351, 3 speed auto trans, dual rear wheels. Edelbrock 600 cfm electric choke, performer intake and ford linkage kit. No other mods.
Old Mar 5, 2003 | 12:06 AM
Franklin2's Avatar
Franklin2
You should have a vacuum line running down from the manifold to the passenger side rear of the transmission.
