Sponsored by: Kumho
Spring /string deep bass sound rear
Old Dec 21, 2010 | 02:15 PM
d5332's Avatar
d5332
I have a sound that can be normal…I was fixing my brake light and heard it a few times…
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
From underneath the truck, somewhere between the driver door and the rear axle I am hearing a noise…
<o></o>
The noise sounds like a musical note…a deep bass string being played type of noise…
<o></o>
It’s the kind of sound that you can make when playing with rigid springs or a deep bass guitar…
<o></o>
The truck was in park….I am wondering if its an indication that there is something wrong with the rear brakes or rear axle….
<o></o>
Is this something that I should be worried about or is my truck just a box full of tricks now….
Old Dec 24, 2010 | 10:49 AM
d5332's Avatar
d5332
Seriously, no one has had this issue?
my truck sounds like a barge pulling in to dock....I think its the brakes because I can hear it from the rear drum if I am standing outside but I can hear it while inside....
Is this a brake thing? sounds like bongggggggggg, deep bass sound....
Any clues?
Thank you and Merry Christmas to all.....
Old Dec 24, 2010 | 12:10 PM
Lazy K's Avatar
Lazy K
The description in your first post reminded me of the sound you get if the brakes are lightly applied and the truck inches forward.
My guess would be that one or both of your rear brakes are draging a little, maybe due to a sticking wheel cylinder or a build up of dust.
One suggestion would be to pull both drums and brush or blow out any dust and do a visual inspection.
Old Dec 27, 2010 | 08:53 AM
d5332's Avatar
d5332
bump...
Still sounds like a barge is pulling in to dock....bonggggggggg
can it be the breaks? stressed bearing or joint?
Old Dec 28, 2010 | 07:11 AM
bashby's Avatar
bashby
In your first post you said the truck was in park, were you just standing next to the truck and heard something? Is it as you come to a stop? Does it just do it once or repetively? If you can get it to make the noise while you are standing beside (or laying under) the truck maybe you can pinpoint it a little better.
