Heater core
Old Jan 14, 2003 | 07:51 PM
kev_89_f150's Avatar
kev_89_f150
Heater core
I have an 89 f150 that is over heating. It takes quite a while for it to over heat. I've put in a new thermostat and checked the pump. I took off the heater hoses and tried to blow air through the core it seems to be plugged. Is there a valve that stops the circulation, or do I have a plugged core. If it is plugged, how do I get it unplugged? Thanks guys, I appreciate your help.
Old Jan 14, 2003 | 08:00 PM
EPNCSU2006's Avatar
EPNCSU2006
Heater core
I don't remember a valve in an 89, and I don't think this is your overheating problem (I could be wrong), but if it is clogged, it's probably just as quick and easy, if not cheaper to just replace it. I got a brand new replacement from NAPA for $20.
Old Jan 14, 2003 | 09:29 PM
steve83's Avatar
steve83
Heater core
There's no OE heater core valve in FS Ford trucks '80-96, but the water in the core could make you think the air wasn't moving if you only applied pressure for a moment. A plugged or even deleted heater core won't cause the engine to overheat - you have other issues.
Old Jan 15, 2003 | 05:32 AM
marragtop's Avatar
marragtop
Heater core
I agree a plugged heater core wouldn't cause it to overheat. Perhaps a clogged radiator??
Old Jan 15, 2003 | 11:21 AM
tsheriff's Avatar
tsheriff
Heater core
This may sound dumb but if you are running the stock clutch fan the clutch may be bad and not be putting enough pressure on the fan to spin it fast enough to keep the motor cool .
Old Jan 15, 2003 | 11:43 AM
gd4u2's Avatar
gd4u2
Heater core
