Flywheel HELP?!?
Old Mar 4, 2003 | 10:55 AM
68_351_TT's Avatar
68_351_TT
Question Flywheel HELP?!?
Okay. I have a 5.8L from a 93 Van. It obviously had an auto tranny. Im trying to figure out what flywheel will fit, cuz I tried a 351M fly, didn't work, tried an old 289 fly, didn't work. Is the flywheel for this motor going to be a 5.0 flywheel, if so 28oz. or 50oz. I thought the bal on this motor is a 28oz, correct me if im wrong, (Please!) Any help appriciated.
-Ryan
Old Mar 4, 2003 | 11:49 AM
Racerchuck's Avatar
Racerchuck
Flywheel HELP?!?
Your 93 351 is a 50oz. balance. This was started in 1981.
Old Mar 4, 2003 | 05:30 PM
ecarter50's Avatar
ecarter50
Flywheel HELP?!?
351w is 28oz. 302 changed to 50oz in 82/83. Any 351c, 351m, 351w, pre 82 302 flywheel/flexplate should fit. Why wouldn't the 289 or 351m flywheel work the crankshaft bolt pattern or pressure plate?
Old Mar 4, 2003 | 11:11 PM
1993F150XL's Avatar
1993F150XL
Flywheel HELP?!?
ecarter50 is right. You need a 28oz. flywheel.
Old Mar 5, 2003 | 11:41 AM
68_351_TT's Avatar
68_351_TT
Flywheel HELP?!?
Yeah the bolt patterns on the 351m flywheel are diffrent.
Old Mar 5, 2003 | 03:12 PM
ecarter50's Avatar
ecarter50
Flywheel HELP?!?
The crankshaft bolt patterns are the same. Turn the flywheel until all 6 holes line up. They are drilled so it will only fit in one position.
