Help! HPOP fitting miscue!
Old Dec 20, 2010 | 11:48 AM
dampink's Avatar
dampink
'05 F250: After warm hard start turned to no-start, I did considerable research and got lots of advice. Sio I took out the HPOP to replace what I assumed to be a bad STD fitting. Turns out the prior owner had already had this done. So now here I sit. Could anyone give me direction on where to go next? Bad IPR? Bad Orings on the injectors? HELP!
Old Dec 20, 2010 | 12:09 PM
solaratomic's Avatar
solaratomic
Most likely a leak somewhere else in the HPO sys. Check standpipes/dummy plugs. There is an updated part out for these also.
Old Dec 20, 2010 | 05:04 PM
npccpartsman's Avatar
npccpartsman
Air test the system before you put it back together by removing the ICP sensor in the passenger valve cover, and FWIW--just because the fitting was already done doesn't mean it can't fail.
