Manual transmissions
Old Dec 20, 2010 | 03:11 AM
mikey89014's Avatar
mikey89014
Does anyone know of a truck style manual transmission with overdrive that will bolt into a T-19 or NP435 style bellhousing? I was thinking of a 10 speed style or something similar.
Old Dec 20, 2010 | 10:47 AM
bghnkinf250's Avatar
bghnkinf250
Not for that size bellhousing. You have two options if you want 10 or more speeds - either a Brownie Box or using an SAE #2 (I think this is the size) bellhousing and then bolting the trans up to that. These engines have the SAE bellhousing on the backs of the engine and use an adapter to go to the Ford bellhousing pattern.
Old Dec 20, 2010 | 01:16 PM
mikey89014's Avatar
mikey89014
ok thanks , i wonder where i can find a n sae #2 housing?
