Coolant Filter
Old Feb 5, 2011 | 11:18 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
............NOW!
Old Feb 5, 2011 | 11:19 AM
bpounds's Avatar
bpounds
Originally Posted by 1buckeyefan
I put my coolant filter in less than 3,000 miles ago. When should I replace the filter?
Thanks,
Mike
Originally Posted by www.dieselsite.com
Recommendations on filter changes:
Use one filter every three months for the first nine months after installation. The lack of flow into the expansion tank is an indication that your filter is plugged. Change the filter if it should plug before the 3-month interval. After the 4th filter is installed your filter should be changed once per year.
The above is the Dieselsite recommendation. On mine, I had recently done 3 flush/fills, so I have not followed their schedule. I am at about 9 months now, and I am monitoring the return line to determine when the flow has slowed. I intend to change it at 1 year, whether the flow indicates the need or not.
Old Feb 5, 2011 | 06:26 PM
Nitrous's Avatar
Nitrous
http://www.detroitdiesel.com/pdf/voc...Selections.pdf
Look at page 18 or 19 of the above file under "drop out" and perhaps this is what is going on in the apparently sand-free filter element paper.
Old Feb 5, 2011 | 09:35 PM
miner999r's Avatar
miner999r
I can agree with the drop out noted in the post above from the Detroit diesel info. Recently I was on the other form I think powerstroke org forum, and there was a post that had pictures of an oil cooler cut in half. It had globs of antifreeze coloured gel like globs in the coolant passages blocking the flow. When the globs dried they formed a white to gray / red powder. Possibly and I am just guessing the high heat in the egr cooler is causing the gold coolant to thicken and gel. I wish I could find that post again. Didn't have a chance to get at the old filter yet - maybe tomorrow. The Detroit diesel doc says talks about flushing the engine to get the slime out, but if allowed to dry in side the engine it has to be dismantled to clean it, not something to look forward to!
Old Feb 5, 2011 | 09:53 PM
miner999r's Avatar
miner999r
You may have seen this but ..... I found the links to the other site that had the pictures of the coolant gel blocked oil cooler.
Post Coolant flush do i need to test? - Ford Powerstroke Diesel Forum
Replaced oil cooler still difference in temps - Page 21 - Ford Powerstroke Diesel Forum
here are some links to that post: Got questions about your 6.0? http://www.powerstroke.org/forum/6-0...ning-6-0l.html
Still runninng Ford Gold Coolant? http://www.powerstroke.org/forum/6-0...ml#post2063212
F250_
Dec 14, 2013 02:50 PM
IHpuller450
6.4L Power Stroke Diesel
Oct 22, 2013 01:48 PM
05 f250 6 inch lift
Sep 25, 2012 08:20 PM
jfirstford
May 26, 2011 12:29 AM
Beachbumcook
Aug 6, 2004 04:46 PM
