Newer vs. older D60
Old Dec 19, 2010 | 04:14 PM
cabloom300's Avatar
cabloom300
Newer vs. older D60
My buddy has a D60 from an 78 or 79 or possibly low 80's truck i believe, question is can i use the LS from it and swap it into my highboy D60? Also if i cant do that, is the swap straight forward? I would imagine I might have to switch the spring perches. Anything else? Thanks
Old Dec 20, 2010 | 01:38 PM
ChaseTruck754's Avatar
ChaseTruck754
I BELIEVE the LS will swap right over. Not 100% positive though.
As for the swappnig the whole axle in thing - it's a pain to do if the axle is 80+ and your truck is a 70's or earlier truck. The pumpkin if moved out towards the knuckle more on the later trucks and since the spring perch is built into the pumpkin this makes putting a newer axle on an older truck a bit tricky unless you go to a coilover and radius arm or 4 link style front suspension.
As a quick reference to show you what I mean here are a few pics of an 80's D60 alongside a 78/79 d60. Notice the pumpkin is closer to the end of the axle on the newer axle.
Old Dec 20, 2010 | 01:41 PM
cabloom300's Avatar
cabloom300
Thanks for the help however i just found that its a 10.25 from a 90's truck so i think il just leave it alone rather than swapping the axle
