Sponsored by: Real Truck
HELP!!!
Old Dec 19, 2010 | 09:41 AM
SnoPro1234's Avatar
SnoPro1234
Exclamation HELP!!!
Hey guys. I am not on here often but the few times i have had problems with my 99 F250, the site has helped me greatly, so i figured id post my new problem. Thanks so much in advance for any help!
Problem: About 2 weeks ago i noticed at low throttle, there was a whining noise coming from the right side of the engine compartment and i had 0 boost. When i gave it more gas it would go back up to normal boost and no noise.
Then i noticed when i pulled in the driveway that i was leaking gas from the front of the engine compartment. I got underneath it and noticed there was oil leaking as well. So i took apart the ducting leading to the turbo and noticed there was oil leaking from the bottom of my turbo.
SO, i took it to a local diesel mechanic that works on the side to fix it reasonable. What he told me was that the HPOP is bad, the turbo needs to be rebuilt, and the ECM is fried.
Does anybody know if this sounds right, or is he full of ****?
Thanks!!
-Matt
SnoPro1234's Avatar
SnoPro1234
Oh, the truck is a 1999 F250 7.3 early build.
Old Dec 19, 2010 | 10:12 AM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Try 7.3 forum ,might get more info there.
Not kicking you out or anything but engine specific forums are loaded with more knowledge about them.
Old Dec 19, 2010 | 10:24 AM
SnoPro1234's Avatar
SnoPro1234
Thanks! I didnt even see the 7.3 section before. Lol
factory581
Oct 26, 2007 09:39 AM
Bushwhacker
Jan 23, 2007 11:43 AM
Wolverine69
Oct 4, 2006 03:06 PM
bumbklaatt
Jun 28, 2006 12:10 AM
cads03
Oct 14, 2004 09:27 AM
