Heater Problems
Old Jan 15, 2003 | 06:45 PM
JW 4x4's Avatar
JW 4x4
Heater Problems
On my '95 Ford F-350 4x4 XLT, the heater just started acting up the other day. When I have the heater turned on full blast or even medium, it will act normal most of the time but randomly the air will turn cold for about 5 seconds then go back to being warm. It does this several times and doesn't seem to heat up the truck like it used to. Also on startup I hear a water/antifreeze running noise on the passenger side of the truck possibly behind the glove box. Not sure if this is related. Let me know what yall think I am cold up here in Ohio Thanks
Old Jan 15, 2003 | 06:50 PM
mrwizard's Avatar
mrwizard
Heater Problems
[updated:LAST EDITED ON 01-15-03 AT 07:51 PM (EST)]Sounds like you may be low on antifreeze. Check the level in the radiator. I had a similar problem with a Ranger I had that had a pinhole leak in the radiator.
Hey, your truck looks like the same color as mine.
Old Jan 15, 2003 | 07:00 PM
JW 4x4's Avatar
JW 4x4
Heater Problems
Thanks for the info. Actually the grey truck in the picture is the '92 Ford F-150 4x4 I used to have but since then I bought a black '95 Ford F-350 4x4. If you want to see a picture go to my gallery. Thanks again
Old Jan 15, 2003 | 07:28 PM
jakegypsum's Avatar
jakegypsum
Heater Problems
racer87f
1997 - 2003 F150
Jan 4, 2015 11:35 AM
pdqtimetrialer
Nov 14, 2009 10:44 PM
Mike_TN
1997 - 2003 F150
29
Feb 6, 2008 02:32 PM
F2504x4
Ohio Chapter
May 18, 2007 02:17 PM
shenders99
Nov 12, 2006 06:57 AM
