Loud screaming noise
Old Dec 18, 2010 | 12:16 PM
Dev's Avatar
Dev
i have a 89 7.3 IDI, its making a very loud diesel screaming noise when im not under load but just cruising, the only time its ever done it before is when its really cold and then it stops after about a minute when it warms up, but now its doing it constantly going down the highway when it does it its burning a lot richer with a lot more black smoke. i have a pyro and its showing its running pretty normal. Does any one have any ideas?
Old Dec 18, 2010 | 12:37 PM
oreocreaming's Avatar
oreocreaming
does it sound like an intake whistle, belt squeel, can you describle the "screaming" sound a little more?
Old Dec 18, 2010 | 06:41 PM
rodneywar's Avatar
rodneywar
also diesels dont run rich or lean they will over fuel or nothing. it could be a bad bearing on an accessory component
Old Dec 18, 2010 | 06:55 PM
Scratcher's Avatar
Scratcher
Sounds like the water pump bearing might be seizing to me except that when that goes you usually get some smoke from the seized pulley rubbing on the belt. That usually stops you pretty quick if you want to save your belt! Your temp gauge would start going up anyway as no coolant is being pumped. Not saying that's what it is. It may be something as simple as a belt needing tensioned or changed.
Old Dec 18, 2010 | 07:00 PM
dyoungen's Avatar
dyoungen
I 2X the water pump or fan clutch.
Old Dec 18, 2010 | 07:53 PM
Dev's Avatar
Dev
sorry for the confusion, if you know what a power stroke sounds like it sounds louder and more "diesely" then a IDI, my IDI sounds like a stroker only a lot louder obviously not normal for my IDI, it is defiantly over fueling because im geting a lot more black smoke then normal and my fule milage went to crap.
Old Dec 18, 2010 | 08:04 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
how many miles are on this ip?
did you check to see if the cold advance solenoid is turning off? i didn't know they failed in the ON position,but i suppose.....why couldn't they.-dunno.
"excessive rattle" would have likely been a better description than "screaming".
Old Dec 18, 2010 | 08:10 PM
Dev's Avatar
Dev
if your talking about the injector pump, this is the 5th one ive had to put on in 35,000 and the current one has about 4,000 on it
Old Dec 18, 2010 | 08:18 PM
FORDF250HDXLT
ahhh.
there's more to the story.
what is the whole story on this engine?
did you replace the ip(s) yourself? how did you go about it?
where are you buying them?
Old Dec 18, 2010 | 08:43 PM
vervepipes's Avatar
vervepipes
I think it must be possible to fail "On", mine never drops below +/- 900 RPM
Old Dec 18, 2010 | 08:46 PM
Dev's Avatar
Dev
what do you mean how did i go about it? i bought 1 from international, 1 from o'rylies auto parts and 2 from local diesel performance shops.
Old Dec 18, 2010 | 08:47 PM
vervepipes's Avatar
vervepipes
I think "how'd you go about it" might refer to the installation process
snaponprofile's Avatar
snaponprofile
You must have a thin wallet after 5 recent IP's.
Old Dec 18, 2010 | 08:55 PM
FORDF250HDXLT
yeah sorry lol.
how did you install them? or did you have someone do it?
what was the reason for changing it in the first place?
Old Dec 18, 2010 | 09:03 PM
Dev's Avatar
Dev
as far as how i put it in i got a detailed set of instruction's from Dave off of this forum, and i talked to a couple of diesel shops, i didn't pull the timing gears i just undid the 3 bolts on the front and slid the old pump out and slid the new one in lined up with a dowel the rest is pretty straight forward.
