Excursion: What's my problem
Old Dec 17, 2010 | 09:41 PM
dake722's Avatar
dake722
I bought a 01 ford excursion 7.3 and since i have had it i have had a shake/vibration that i thought was just my tires but after a new set and several balances i still have the same problem. I never had a roar or any noise coming from my driveshaft but was told that it could be out of balance, i took it to a machine shop and after replacing the u-joints and a balance i have developed a roar at 45 and continues until 65 and i still have my original shake/ vibration.. i have taken the shaft back to the machine shop and had a different set of u-joints put in and had it balanced again and it's worse. the roar continued after 65 so i had the machine shop build me a new shaft using my yoke and yet another better as he called it set of u-joints put in (non greasable) to have the same roar not after 65 anymore but still at 55 so i have a problem so where that is driving me nuts!!! mostly stock except for new set of michelin's 285/75/16, rancho adjustable shocks including steering stabilizer,and i have a predator tuner on the vehicle. if anyone can help it would be much appreciated!!!
Josh
Old Dec 18, 2010 | 02:06 AM
Rickx's Avatar
Rickx
It's time to crack the pumpkin.
Old Dec 18, 2010 | 09:18 AM
dake722's Avatar
dake722
what exactly does that mean?
Old Dec 18, 2010 | 10:39 AM
Rickx's Avatar
Rickx
That means check your rear differential. I had the same issues. And went through the same process as you the only difference is I took it to a dealer and they started with the rear diff. The clutches in the limited slip were torn up. They rebuilt it and got rid of the roar coming from the back. I still had the vibration, though. They sent the driveshaft out to be checked. It took two diffent shops for the second one to balance it. That cleared up my vibration issue. I don't know if this is your problem, but inspecting the fluid in your rear diff may show you something. The reason I say open it up and physically inspect is it may have fresh fluid in it but not been repaired. The dealer used sensors and a laptop to isolate the source of noise and vibration on a test drive. To assist in this process clean out your Ex and remove your back seat. Take it to someone who can "listen" in this manner.
Old Dec 18, 2010 | 10:44 AM
Rickx's Avatar
Rickx
Another thought. Have them check the angles. You may need to shim the rear end and lessen the degree of angle. That's the the thing about used vehicles, you never know what they've been through.
Old Dec 18, 2010 | 08:38 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
I had the same problem with my 1972 mustang. It was the pinion angle.It would roar or shake after 55mph. Ujoints were taking a beating
The best explanation someone gave me was a driveshaft is like a joperope both handles have to be in sync.
The pinion angle off the trans. nees to be in sync with the angle on the diff.
Old Dec 18, 2010 | 11:01 PM
Stewart_H's Avatar
Stewart_H
Pumpkin = Rear Differential
Crack it = Open it up and diagnose any problems that may be present.
That was gonna be my advice. Check your pinion angle.
Stewart
Old Jan 5, 2011 | 02:20 PM
dake722's Avatar
dake722
Had the front end checked and everything looks great.. possibly the bearing coming out of the transfer case..
sammie0126
Sep 11, 2012 09:16 PM
7.3 Ex
Mar 13, 2011 06:27 PM
GucciSock
Nov 9, 2003 08:47 AM
DrFord
Dec 30, 2002 02:35 AM
