1978 - 1996 Big Bronco
Faulty alternator
Old Mar 3, 2003 | 09:42 PM
Chandleronco's Avatar
Chandleronco
Thumbs up Faulty alternator
Hey there......I've finally fixed the problem. Some of the wires connecting to the alternator had melted together, causing some shorts, and also my alternator was weak, so I had that replaced too. Everything is in great shape now. Thanks for the help.
Old Mar 4, 2003 | 08:57 AM
spixican07's Avatar
spixican07
Faulty alternator
you got lucky. check out my photos and see what can happen when an alternator shorts out. not pretty at all!
Old Mar 5, 2003 | 04:42 PM
Big Red Bronco's Avatar
Big Red Bronco
Faulty alternator
You are lucky!!! When mine shorted out last fall it caused $1500 in damage. Most of the alternator area melted or was fire damaged.
And right now I'm trying to figure out if the cracked head is from the fire.
A couple mintues more before I found the fire, I would not have a Big Red Bronco
Bruce Big Red Bronco 1989. it's waiting its turn to have the engine pulled, behind a 1976 Firebird (this weekend) and the gas tank on a mini-blazer. And the brakes on a 1998 Escort.
