Excursion Tank Mod: ideas and physics help needed
Old Dec 17, 2010 | 03:38 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by JonathanN
True, but with the rear tank being alot deeper than the main tank, wouldn't that be pretty much eliminated if I pulled from the rear tank? What about an "external sump" to hold fuel to make up for that? I have an in-line fuel filter that might act something like that... I don't know, I'm just thinking. I still don't know how it could be an issue with the main tank being as long as it is... I would think that if hilly country was a problem, the length of the main tank would be too which it's not. Doesn't the fuel bowl help make up for a bit of that? Just thinking out loud here...
All fluids find their own level. Both tanks have to be on the same level for this to work.
Otherwise you're going to have to have a dual fuel pump system and switch back and forth like the OBS gassers do, or have a transfer pump that draws from the aux tank and fills the main tank.
Old Dec 17, 2010 | 03:41 PM
JonathanN's Avatar
JonathanN
Originally Posted by Kwikkordead
You talking about the rollover valves? I don't think they have adequite volume to handle venting while filling up.
If I were to do something like you are suggesting, I would run a 1 inch pipe on the bottom and a 1/2 inch pipe along the top with a tee in the middle of both and a vertical pipe between the top and bottom to eliminate any chance of pocketing.
But I still would recommend against doing something like this. Fuel pump draws from the front tank and you are down to less than 1/8 tank and now here is a big hill to climb.
All the fuel will run to the back tank and starve the fuel pump.
Unless you ran the 1 inch pipe from the very front of the tank so that if you had to climb a hill with low fuel, that escape route for the fuel is cut off until you level out again.
I could maybe pull from the rear since it'd hang lower than the front tank... that would act like a sump for sure. But yeah, I guess I could use a valve, I just hate to have a tone of pumps on the truck... I would have to have a pre-pump for each tank. I would then either have to have both pre-pumps running all the time, or rig up some sort of a delay circuit so that the pump for the tank I'm switching to would turn on and prime the supply line before the valve actuates.
In response to your last post, I can see how that'd be if the tops weren't level, but they would be... only the bottoms wouldn't. Would that still cause problems? I wish I could simulate the whole thing with a small scale model...
Old Dec 17, 2010 | 03:43 PM
JonathanN's Avatar
JonathanN
Originally Posted by RMBC Freeride
Sorry for the threadjack, but if anyone needs an Excursion fuel tank, I have an extra one. Shipping might be an issue though, since it had gasoline in it. Same as the diesel tank AFAIK, except for the pickup assy.
Now back to physics class...
Man, I would if I had money to spend right now... I was just trying to plan this thing out and find out if it's even something I'd wanna fool with. Thanks for the offer... I may PM you one of these days and see if you still have it.
Old Dec 17, 2010 | 03:52 PM
bama29fan's Avatar
bama29fan
only way i can picture it working is to have two fill necks....one for each tank and then a check valve in the pipe between the two tanks.
as for small scale...i have seen the two gallon water jugs (from walmart) that you put in you fridge (the have a tap). they are somewhat rectangular (similar shape as fuel tank) and cheap. you could then pipe them together somehow to test the system. im sure theres other ways but thats what first popped in my head.
Old Dec 17, 2010 | 03:55 PM
JonathanN's Avatar
JonathanN
Hmmm, with that in mind, milk jugs would work good... we have those floating around here all the time! I'm gonna have to make a model...
Old Dec 17, 2010 | 10:14 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
My thoughts exactly. Two filler necks, and check valve between the tanks. Could add a second pump to pump fuel between the tanks with switch in cab to turn on and off pump. Plus a fuel guage to see the tank level. K. I. S. S......Keep it simple.....
Old Dec 18, 2010 | 09:20 AM
Kwikkordead
K.I.S.S.
That's why I like my Transfer Flow aux tank.
Fill it and forget it, the system monitors it from there.
90pioneer
22
Sep 15, 2017 09:35 PM
RyRoRyan
Jan 21, 2016 11:35 AM
ranagent
Dec 4, 2015 10:35 AM
SteelSteeds
Aug 16, 2015 07:03 AM
lud04X
Dec 3, 2011 09:58 PM
