I need to know the gearign for a 1979 Bronco. The engine that was in it is unknown. All I need is the gear ratios in a bronce in 1979, all engines.
Did the have 3.55's?
I just blew apart ANOTHER axle and am sick of this damn twin I beam suspension in my '83 F150. I am looking to convert to a solid axle from a 1979 bronce and the only thing i need are the possible gear ratio's.
The problem is, I want the same gear ratio. As I do drive this truck on the road and sometimes on the interstate. I want to be able to cruise with it @70 mph and not be turning 3500+ revs.
About how much will 33X12.5X15's throw off the speedo? Compared to stock size tires.
Also, where is a good place to get ring and pinion gears?
