Sponsored by: Auxito
1998 4.6 missing
Old Dec 14, 2010 | 10:59 PM
tdrummond's Avatar
tdrummond
1998 4.6 missing
Hi, first of all let me give you the background on the truck. It's a 1998 F150 4x4, with a 4.6l v8 and 205,000 miles.
The problem started when I was driving home from work today. It ran fine on the way in, but halfway home it started to miss and sputter. I ran into town and put some fuel stabalizer in it along with a full tank of gas (not really expecting much) it didn't do anything.
I replaced the plugs and wires last summer with OE parts (learned the OE lesson the hard way) The check engine light has been on for over a year reading EGR flow malfunction, it never affected the way it ran so I never fixed it.
It sputters at idle, and all the way up to cruising speed; also it "surges" and will run fine for a second (at idle and cruising speed) but then quickly reverts back to the shaking and sputtering. Has anyone had a similar problem who could lend me some advise before I go on a wild goose chase, and, or spend a bunch of money?
Thanks,
Evan
Old Dec 15, 2010 | 06:07 AM
Joe Finn's Avatar
Joe Finn
Get the codes read and post them here.
Old Dec 15, 2010 | 10:26 AM
tdrummond's Avatar
tdrummond
Cylinder seven misfire. Are the injectors prone to failure on these trucks? I guess anything is prone to failure at 205,000mi though...
Old Dec 15, 2010 | 01:22 PM
tdrummond's Avatar
tdrummond
Well, I believe I have cornered the problem. If you read my original post, where I mentioned putting in new OE motocraft plugs....I should elaborate, I should have said, "I told the mechanic to use OE motocraft plugs"....He said he did (and charged me for them), but when I removed and inspected the number seven plug (just to be safe), I discovered it was a three dollar autolite. So, OE plugs (installed by me this time) took care of the problem.
Chuck999
1997 - 2003 F150
Mar 5, 2013 02:20 PM
Expedish98
Oct 31, 2012 01:44 PM
mikieday
1997 - 2003 F150
Jan 4, 2010 08:57 PM
ebacherville
May 2, 2002 08:53 PM
ebacherville
1983 - 2012 Ranger & B-Series
Feb 7, 2002 09:42 PM
