Yet another sad tale...
Old Dec 14, 2010 | 08:44 PM
6point0's Avatar
6point0
... all stock, but apparently to much power..
Side roads were snow covered. Main highway was clear. Crazy 5 PM traffic. I put the diesel in 4x4 high. hold the brake, bring the rpm up.
see the hole in traffic coming, BAM off we go. get out on the straight kick in in 2wd off we go, right to the rug from the stop.
Get down the road, notice a clunk coming from under somewhere,
pull over, check it all out, evertthing seems good, U joints-drive shafts bla bla..
Decided I had better take it home, Turn around, being easy on it
Right rear tire locks up, and im not 100% sure that it has 4x4 now...
Man..... .never ends. Im fixing it and selling it........ I think
Old Dec 14, 2010 | 09:06 PM
wulfman's Avatar
wulfman
So what are you saying happened with the truck.
Old Dec 15, 2010 | 10:14 AM
6point0's Avatar
6point0
Sorry, it was a long day. Right rear tire is locked up solid. and I think , THINK the T-case may be out of it
Old Dec 15, 2010 | 10:52 AM
counciller's Avatar
counciller
What is telling you the T Case is messed up
Old Dec 15, 2010 | 12:03 PM
6point0's Avatar
6point0
Didnt sound like any other T case I have ever wrecked, But the light was on, and it didnt feel like there was 4x4. truck had some wicked " thumps" going through it though, from something be broke badly
Old Dec 15, 2010 | 01:36 PM
wulfman's Avatar
wulfman
Right rear locked up, maybe rear end messed up. unhook rear drive shaft see if front end will pull it. or if anything turns up front. if its just right rear i would bet brakes. pull rear wheel off check brakes. I dont think its the transfer case. they are stout cases, you would have to something really bad to screw it up.
Old Dec 15, 2010 | 01:40 PM
6point0's Avatar
6point0
Yeah, my buddy thought it could be brakes also. I'm doubting it because of the banging that was going through the floor * shrugs* Gonna work on it saturday and see what happens.
Old Dec 15, 2010 | 01:49 PM
wulfman's Avatar
wulfman
Good luck with it
Old Dec 15, 2010 | 01:52 PM
6point0's Avatar
6point0
Thanks man, but there has been no luck with this truck. Its sweet, but im actually thinking of selling it this time around
Old Dec 16, 2010 | 11:11 AM
steelhead2's Avatar
steelhead2
id say broken axle or spiders gone.
Old Dec 16, 2010 | 11:59 AM
counciller's Avatar
counciller
im gonna guess that full throttle blast up the on ramp had that wheel spinning and it probably hit a dry spot and slowed down really really quickly. im thinking you have a screwed up rear gear assembly
