wont's start won't run
Old Dec 14, 2010 | 03:18 PM
elizabethdaniel72's Avatar
elizabethdaniel72
I got a 93 Ford F150 in line 6, the truck will start up and immediatley shut off, I have replaced the computer, alternator, fuel pump, fuel filter, coil, ignition module O2 censor, ATC censor, and throttle positioning censor, it still starts up and immediatley shuts off, will not stay running at all, I am pretty good with mechanics but I am at a complete loss with what is going on with it, any help will be greatly appreciated
Old Dec 14, 2010 | 04:05 PM
LxMan1's Avatar
LxMan1
Sounds like a bad ignition switch under the column. Try holding the key slightly past on and before start after cranking. I have seen this many times.
Oh yeah, moved to correct forum.
Old Dec 14, 2010 | 06:05 PM
subford's Avatar
subford
If not the Ignition switch try replacing the PIP sensor.
I would say just replace the distributor but most of the time you get a bad one from the auto part stores.
