That would work for to check codes but I don't think it would work for gauges because I need glasses to read it but not to drive so it would be too fuzzy to read. I can't read the odometer while driving. Are there any other gauges that are more reader friendly?
Looks like the CTS has a 4.3 inch screen. Which a person would want if they got the back up camera with it. If you were going this direction I would inquire about getting it with the EGT probe.
I have no white smoke and no signs of puking, the level is 1/2 to 3/4 below the min mark. So maybe that is not the problem. The dealer had marked the bottle on the min line as the new full mark that is why I thought the coolant was going down.
I got a Edge Insight plugged into the truck and found codes P0263, P0299, and P0500. Zero boost at idle and 8 to 10 when I hit up around 2500 rpms. My EOT and ECT are within 2 degrees with the coolant leading the way so I think the oil cooler is OK right?
