BrakeMotive PowerStop Rotors for the Ex
I just ordered mine from ebay today. Brakemotive didn't have the good deal anymore, so I went with brakeoverstock. $254, free shipping. Frt, and rear rotors and ceramic pads. I'll post back when I get them installed. I think I read on here that the caliper pins can sometimes be a PITA. Any suggestions for a smooth installation before I begin fellas?
Try PB blaster.
Put flat side of pin in vise. try to move left to right.
If that doesn't work and you don't have heat then an air chisel with a flat blade against that flat part of pin outward away from pin holder.
PB blaster.
If you get it loose then use the pin with the rust on it to clean out bore of holder 1st till pin is loose in bore.
Then sand paper to pin,brake clean bore.
Autozone sells synethic brake lube.
Lube the pin alot/bore.
Maybe buy a brake kit hardware.
GOOD LUCK
9mpg,
Small world. WC, PA represent! Maybe we've crossed paths and thought "hey, another Ex". Chances are better that you've seen my wife as the Ex is her daily armored, ankle-biter carrier. The Estate Green Limited with the little blonde riding the white line and scratching the **** out of the passenger side, and hammering the throttle on launches would be her.
Anyway, I think (or HOPE, considering I already committed to buy) I just picked up the same rotors and pads package you did from Brakemotive76. I can't quite tell because I can't see your exact eBay item from the link. I was just curious about a couple things: Did the rotors come in oem packaging and if so, were they branded PowerStop or is just the pads that are PowerStop? The ad would suggest that they're not PowerStop branded. I guess I'm not especially concerned about it, as I see your follow-up post is still favorable that it's a decent product. Anyway, I was hoping you'd be kind enough to clarify.
Cheers,
Will
Cheers,
Will
Last edited by Xdaddy517; 04-11-2011 at 01:41 PM. Reason: Got poster's screen name wrong
9mpg,
Cheers,
Will
Cheers,
Will
One thing I will tell you: it takes a little more pedal pressure to stay stopped at red lights. (probably from the small loss of surface area where the drilled holes and slots are) When I first put them on I would find myself creeping forward until I got used to it.
Did you get the parts yet?
How long did it take to get them?
How aqre the brakes now?
Did you do any resource on copmpany who made the parts?
