PCV w/ 2 Ports??????
Ok, from some previous posts I had, replacing the PCV valve was recommended. So, I ran down to the local parts house and looked it up and got a new PCV valve. My old one had only one 'port' for lack of a better term and this one has two. ???????
I figured that the book was right and some previous owner was an idiot.
So, here is my question. I found what seemed to me to be a vaccuum line that was just stuck on a bolt coming out of the bracket that hold the air pump lines. This line goes to a 'manifold' with 4 ports right behind the distributor that goes into the intake manifold. My vaccuum diagram doesn't show two lines going to the PCV.
I hooked that line up and it seems to run better, is this correct? Or is that line supposed to go somewhere else? This is my first Ford and I am just a little confused.
Thanks for any input.
