2004 450 CUBE VAN ICP LOCATION
Old Dec 11, 2010 | 02:52 PM
blgmachine's Avatar
blgmachine
PROBLEMS WITH NOT STARTING WANT TO TRY DISCONNECTING ICP SENSOR,NOT SURE WHERE IT IS ON THIS CUBE VAN.
THANKS GUS
Old Dec 11, 2010 | 03:36 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I think it is only in 2 places. Either on the passenger valve cover, late build motors.
Or under the turbo on the back of the engine, early build
EARLY BUILD LOCATION BELOW:
LATE BUILD LOCATION BELOW: (lower part of picture)
Old Dec 12, 2010 | 07:25 AM
blgmachine's Avatar
blgmachine
ICP SENSOR LOCATION
STILL CANT LOCATE.TRUCK WAS BUILT IN 06-04.ALSO WHAT PART #IS USED
3C3Z-9F838-A OR 4C3Z-9F838-A
NOW IT SHOULD BE FUN TO WORK ON WITH 14" OF SNOW AROUND IT.
THANKS GUS
Old Dec 12, 2010 | 08:24 AM
amdriven2liv
I wasn't sure if they put it somewhere else for the vans. Other than those 2 place, I'm not sure where you'd look. I'll try another bit of info. All the info I have shows the ICP in the same location on the F series and E series. Yours should be on the passenger side valve cover.
Diesel Technician Society
Old Dec 12, 2010 | 08:28 AM
amdriven2liv
I looked in both the F series and E series section of this book. Found in the link in my last post.
Old Dec 12, 2010 | 08:31 AM
amdriven2liv
Might have the right part number here.
https://www.ford-trucks.com/forums/1...sguy-help.html
Old Dec 12, 2010 | 08:46 AM
cheezit's Avatar
cheezit
same spot in a van just much harder to get to.
maf226
Mar 3, 2013 08:16 PM
nmenthompson
Modular V10 (6.8l)
Jul 26, 2007 10:56 AM
al_41stakebed
1947 and Older Ford Trucks
Sep 7, 2006 09:46 PM
jagarner
Dec 4, 2003 07:55 PM
78f3504x4
Mar 30, 2003 03:13 PM
