? body mount rubbers
Old Dec 10, 2010 | 11:01 AM
miottimouse's Avatar
miottimouse
Unhappy ? body mount rubbers
good day i want to remove the rubber bisket to lift the cab up a bit to paint the frame and when i undo the nut/bolt the 2 halves dont seem to come apart like there is a sleave with a ridge that is catching is there a trick to getting these apart? with out dammaging them? thank regurds joe
Old Dec 10, 2010 | 11:23 AM
Witty73's Avatar
Witty73
First of all, the nut is part of the bottom plate. If you have gotten the bolt loose, and out, you simply need to leave it part way threaded into the nut and tap on it to seperate the two halves. May be a little trickier with the cab still on, but Im sure it can be done.
Old Dec 10, 2010 | 11:53 AM
kentucky19's Avatar
kentucky19
Some of them are pretty much imposible to seperate where they are rusted together.
Old Dec 10, 2010 | 05:48 PM
ChaseTruck754's Avatar
ChaseTruck754
Yup. All I've seen are rusted together and I've had to drill out every one I've ever messed with...
Old Dec 11, 2010 | 05:23 PM
Tees77f150's Avatar
Tees77f150
Just went through this battle with my right rear cab mount, and what a battle it was. I got it apart, but it was destroved in the process. I am about to order a new one, and finish it up, but I an going to wait till after the holidays to do it. Its not a daily driver, but a fair weather toy which works for me.
Old Dec 11, 2010 | 05:40 PM
79 f350ts's Avatar
79 f350ts
when doing the teardown on my 79 , i ran the bolts back in as mentioned above, but it took more than tapping. I had to beat the living s@#%* OUTTA THEM. the bolts were rusted into oblivion anyway as were the mounts , so gonna replace anyway theyre not that expensive
Old Dec 11, 2010 | 06:20 PM
miottimouse
ya thats what i thought any one know where to get a set for all 4 corners? was thinking about polyurathane but might be to harsh of a ride being a one ton and all stock type rubber is what i would like to go with if i can find a set any one name a place?
Old Dec 11, 2010 | 06:43 PM
79 f350ts's Avatar
79 f350ts
LMC, Dennis Carpenter and NPD are good for starters i'm sure others will be along with more. Personally i would go with rubber, not nearly as harsh on the ole bum
Old Dec 11, 2010 | 08:41 PM
kentucky19's Avatar
kentucky19
autozone has the poly ones but im not sure about rubber.
Old Dec 12, 2010 | 01:10 PM
miottimouse
i found and ordered the rubber kit from npd $99.00 there on their way
