cam vs California
Old Mar 3, 2003 | 12:14 AM
cjcathey2002's Avatar
cjcathey2002
cam vs California
just got my truck smogged not to long ago in california. it passes with ease. but i have been cintemplating a cam upgrade, i have the stock cam in it now. so what is the stock cam numbers for a 77 460? i have put headers and dual 40 series flowmasters that exit before the wheels, edelbrock cam and holley carb. msd 6a ignition, blaster coil, open element air cleaner. i am guessing that with all that i have done i probably have close to 300 hp and like 400 ft lbs? does that sound reasonable, or do i have more power? but i am going to be doing a lot of work to my truck this summer, and i would like even more power out of it. i am hoping that i can get a cam that will beat the sniffer test but still make a lot of power. any ideas? whats the best cam toi get? i have heard that changing the timing chain will gain more power but i think that would hurt emissions and i have heard stories about it making the truck run worse....
Old Mar 4, 2003 | 09:39 AM
georgedavila's Avatar
georgedavila
cam vs California
You're in a very unusual position in seeking more power while attempting to appease the CA smog *****. The timing gear on your '77 was purposefully retarded to reduce emissions (and power). Advancing it to a straight-up assembly will improve power, but at the same time increase emissions. I'd suggest talking to some of the cam grinders and getting their recommendations for your particular situation.
Old Mar 4, 2003 | 01:59 PM
pagere2's Avatar
pagere2
cam vs California
As far as stock specs for the cam, I found this web site http://www.clevite.com/motorhead/tec...ecs/ford.html. My Ford service manual lists the cam lift as .274" and .278", so I think the data for the 460 on this website is accurate.
Question: Are you saying that your truck passed the smog test with the stock cam or the Edelbrock cam?
thanks, pager
Old Mar 4, 2003 | 02:59 PM
georgedavila
cam vs California
I show the '72-78 CA 460 as .443/.424, non-CA .443/.486.
As a contrast, the CJ was .506/.506.
Old Mar 4, 2003 | 05:27 PM
pagere2's Avatar
pagere2
cam vs California
Sorry guys. I screwed up on those numbers. I don't know how I came up with those numbers. Anyways, the information I was trying to present was from an 87 manual. I didn't notice that you were looking for the numbers for a 77.
Old Mar 4, 2003 | 10:53 PM
fudds1's Avatar
fudds1
cam vs California
Call Comp Cams here is there tech #1-800-999-0853 Here is the web www.compcams.com
hustler54
1983 - 2012 Ranger & B-Series
52
Sep 24, 2013 10:09 PM
breno1987
Sep 5, 2011 11:35 AM
smoke n tires
Dec 11, 2008 09:21 PM
1972 Ford Thunderbird 429 V8
Mar 26, 2003 07:55 PM
cjcathey2002
Aug 13, 2002 09:02 PM
